Changing local file location when editing
bl4nk
Post by bl4nk » Fri Oct 03, 2008 9:04 pm
Choose to edit a file and then right click the file on the transfer queue and go to Properties. Click the "Select File" button to the right of the local directory section and choose the new file you want to use for the source and hit OK on the properties box. Now if you go and edit the file that you chose as the new source file and save it, it won't be picked up by SmartFTP. To get it to start monitoring the correct file, you have to stop the transfer queue and start it up again, and then from there on it will start monitoring the correct file.
Re: Changing local file location when editing
Post by mb » Fri Oct 03, 2008 9:16 pm
Thank you for reporting. Will be fixed in the next build.
Post by mb » Wed Oct 29, 2008 4:18 pm
I believe the latest version fixes the problem:
Can you confirm this?
