Folder View In Panes For Remote Browser Doesn't Work
keith10456
Post by keith10456 » Thu Sep 11, 2008 2:23 pm
In build v3.0.1022.25, while in a Remote Browser, if I go to View > Panes > Folder View nothing happens. Even if I press Shift+F2 nothing happens.
The Folder View works correctly in the Local Browswer but not in Remote Window.
Note: I restarted computer, closed SmartFTP, etc. Same result (Windows XP w SP2).
Re: Folder View In Panes For Remote Browser Doesn't Work
Post by mb » Thu Sep 11, 2008 4:48 pm
1. Go to Start Menu
2. Select Run..
3. Enter regedit.exe
4. Press Enter
5. Delete the following registry key: HKEY_CURRENT_USER\Software\SmartFTP
