Favorites window flickers...
kkez
Post by kkez » Fri Sep 05, 2008 9:13 am
I have the favorites panel on my second monitor. If i remove a folder with files in it, for each time a file or folder is removed, the favorites panel is refreshed, which makes the delete process go slower (and the CPU goes 100%). Why does it need to be refreshed? Can you stop that?
Re: Favorites window flickers...
Post by mb » Fri Sep 05, 2008 3:45 pm
Please install the latest version of SmartFTP:
If the problem persists please post the system information from the menu: Help->About System Information.
kkez
Post by kkez » Mon Sep 08, 2008 2:20 pm
Post by mb » Mon Sep 08, 2008 8:33 pm
If you have the favorites window on the first monitor does it flicker as well?
kkez
Post by kkez » Tue Sep 09, 2008 9:38 am
Yes, it does.
BTW, actually it doesn't flicker (which for me it means the window refreshes itself many times), it seems to refresh itself each time the directory listing is downloaded.
Post by mb » Tue Sep 09, 2008 9:58 am
Are you able to reproduce this on another computer as well?
