Transfer icons disabled, but transfer possible by drag and drop
ruirib
Post by ruirib » Fri Aug 01, 2008 11:00 am
When I choose the Desktop folder in my local browser, the upload and download icons are disabled. I can upload and download files through drag and drop, so why are the icons disabled?
Looks like a bug...I'm running version 3.0.1024.4.
Re: Transfer icons disabled, but transfer possible by drag and drop
Post by mb » Fri Aug 01, 2008 11:02 am
Bug confirmed. Fix in next build.
Thanks for reporting it.
ruirib
Post by ruirib » Fri Aug 01, 2008 11:03 am
Thank your for a prompt reply.
ruirib
Post by ruirib » Fri Aug 01, 2008 11:22 am
Just downloaded version 3.0.1021.7. The upload icon behavior is fixed, but the issue persists with the download icon.
Just reporting again, because the change log for this version seems to indicate the issue is totally solved. I apologize if you knew about it already.
Post by mb » Fri Aug 01, 2008 11:25 am
The newest version with the fix has not been released yet.
Post by mb » Fri Aug 01, 2008 9:54 pm
It has been released now:
