Cannot upload files by dragging from local to remote window
9xb
Post by 9xb » Wed Jul 30, 2008 7:47 am
Service Pack 3 (Build 2600)
CPU Speed : 3192 MHz
Total Memory : 2038 MB
Free Memory : 1445 MB
Version : 3.0.1021.7
Time Stamp : 2008-07-30 04:23:37
Days in use : 417
sfFTPLib.dll : 1.5.13.40
sfFavorites.dll : 1.0.17.7
sfTransferQueue.dll : 1.0.14.7
sfFTPShellExtension.dll : 1.0.12.7
SmartFTPPS.dll : 3.0.1021.7
SmartFTP.exe : 3.0.1021.7
Version : 7.0.5730.11
This used to work but stopped after a SmartFTP update a few months back - basically I can drag and drop files from the remote window to local no problems, but if I drag files from the local to remote windows (upload), nothing happens whatsoever. I can upload by highlighting the files, right clicking them and selecting "SmartFTP > Location" though.
Would appreciate some help on this one! Thanks.
Re: Cannot upload files by dragging from local to remote window
Post by mb » Wed Jul 30, 2008 7:53 am
Please enable the debug logs in SmartFTP as described here:
https://www.smartftp.com/support/kb/how- ... f2613.html
Then start SmartFTP and do the drag&drop operation which doesn't work.
Then send the logs to support at smartftp.com
9xb
Post by 9xb » Wed Jul 30, 2008 8:02 am
Thanks, that's now done.
Post by mb » Wed Jul 30, 2008 1:30 pm
It's the same problem as here:
https://www.smartftp.com/forums/Unable-t ... 14939.html
There are some problems when drag&dropping from a network share. We are looking into it.
