Can't create new folders or favourites in Manage Favorite screen
jesus2099
Post by jesus2099 » Tue Jul 01, 2008 9:46 am
Hello,
I installed the latest version available today.
  • There is a typo in the favourites menu. "Manage favorite…" should be called "Manage favorites…" (with an "S")
  • I can't create any NEW thing in this screen. Neither folder nor favourite. It seems like the same bug than this closed one except that I can see all my old favourites. Why is it like this ? Is the problem only when upgrading ? If so, is the upgrade process improvable for future versions ?
Thank you !!
PS. I came back to SmartFTP from Filezilla because it has the same nag screen when using old versions.
Re: Can't create new folders or favourites in Manage Favorite screen
Post by mb » Tue Jul 01, 2008 2:04 pm
>Typo
This is actually correct. Favourite is British English and Favorite is American English.
>New Folder
Did you restart your computer after the installation? If not please try it. Please post the system information from the menu: Help->About "System Information" dialog.
jesus2099
Post by jesus2099 » Tue Jul 01, 2008 2:19 pm
Hi MB,
typo: Anyway, it seems to me that the trailing "s" is missing.
New folder / New favorite: At that time, no. But now I did and still can't add anything.
Service Pack 4 (Build 2195)
CPU Speed		   : 2793 MHz
Total Memory		: 2039 MB
Free Memory		 : 1212 MB
Version			 : 3.0.1019.4
Time Stamp		  : 2008-07-01 04:44:49
Platform			: x86
Unlicensed
Days in use		 : 307
sfFTPLib.dll		: 1.5.13.32
sfFavorites.dll	 : 1.0.15.4
sfTransferQueue.dll : 1.0.12.4
sfFTPShellExtension.dll : 1.0.10.4
SmartFTP.exe		: 3.0.1019.4
Version			 : 6.0.2800.1106
Winsock			 : 2.2
Post by mb » Tue Jul 01, 2008 2:25 pm
Ah Windows 2000. We will look at it.
Post by mb » Tue Jul 01, 2008 10:01 pm
It is possible to create new favorites in a sub folder. e.g in the Quick Connect folder. And you can use the toolbar to create a new favorite/folder in the root folder.
I hope this helps but I still highly recommend to upgrade to a safe OS like Windows XP or Vista.
jesus2099
Post by jesus2099 » Wed Jul 02, 2008 3:58 pm
Well I still had problems.
Here is how I do achieve to edit my favourites now:
I go in Explore look for the folder where my bookmarks are (D:\Documents and Settings\M319937\Application Data\SmartFTP\Client 2.0). Here, I find two folders: Favorites.old and Favorites.
They are write protected.
I unprotect them and I can create anything I want then in SmartFTP (folder, favourite).
But they immediatly reprotect again.
So I have to unprotect them each time I want to edit my favourites.
(sorry bad english)
Post by mb » Thu Jul 03, 2008 5:58 pm
Did you try it with the latest version? Because I was told changing the attributes is not necessary - anymore.
jesus2099
Post by jesus2099 » Fri Jul 04, 2008 10:35 am
In fact now it is quite special.
If I click on a folder (including the special favorites folder) in the left pane, I can only create a new folder (New Favorite is grey in the menu).
If I want to create a new favourite, I have to click in the right pane first.
In any situation, the right click menu doesn't allow me to create anything (I have to use the Favorite menu instead, in the upper menu bar).
But it's really OK to me now, I can do what I want even if it is a little strange.
Is it a windows 2000 only bug ?
Post by mb » Fri Jul 04, 2008 2:20 pm
Hello jesus ..
The latest update included a workaround to enable the "New Favorite" function through the menu/toolbar. Only Windows 2000 is affected.
