Unable to upload from network drive using 3
james.king@4act.com
Post by james.king@4act.com » Wed Jun 25, 2008 8:01 pm
I can upload fine unless I am uploading from a network drive. When I drag files out of the temporary queue to their location the show up in the transfer queue for a few seconds and then leave the transfer queue but no files have been added to the remote directory.
transfer queue is empty
<?xml version="1.0"?>
<!--TransferQueueItems-->
<Items><Version>1</Version></Items>
Nothing changes in the log.
[14:57:36] NOOP
[14:57:36] 200 Zzz...
Here is my system dump.
Microsoft Windows XP Professional x64 Edition
Service Pack 2 (Build 3790)
CPU Speed : 1962 MHz
Total Memory : 1499 MB
Free Memory : 1066 MB
Version : 3.0.1018.3
Time Stamp : 2008-06-24 17:31:48
Platform : x64
Days in use : 1
sfFTPLib.dll : 1.5.13.32
sfFavorites.dll : 1.0.14.3
sfTransferQueue.dll : 1.0.11.3
sfFTPShellExtension.dll : 1.0.9.3
SmartFTP.exe : 3.0.1018.3
Version : 7.0.5730.13
Re: Unable to upload from network drive using 3
Post by mb » Wed Jun 25, 2008 8:09 pm
Please post the log from the transfer queue item. To get it:
1. stop the transfer queue
2. do the drag&drop operation of one file
3. double click the item in the queue
4. start the queue
5. the log will be displayed in the window that appears in 3
james.king@4act.com
Post by james.king@4act.com » Wed Jun 25, 2008 8:37 pm
4. start the queue
The log stayed blank after I clicked the play button.
The transfer queue itself filled in all of the columns (average speed, Current Speed, ...) for about 2 or 3 seconds (for both a 200KB file and a 40MB file) and then cleared itself.
Again, this is only from a mapped drive. Everything works fine from a local drive.
Post by mb » Wed Jun 25, 2008 8:51 pm
The log should not stay blank even if the local file could not be found. It is important that you test with 1 item only.
james.king@4act.com
Post by james.king@4act.com » Wed Jun 25, 2008 9:01 pm
Post by mb » Wed Jun 25, 2008 9:06 pm
Ah you are using the transfer queue to copy from a local folder (also network drive mapped in windows) to another local folder. Is this correct?
james.king@4act.com
Post by james.king@4act.com » Wed Jun 25, 2008 9:09 pm
No, I am attempting to upload from a mapped drive to a remote ftp folder.
Post by mb » Wed Jun 25, 2008 9:11 pm
But in the screenshot you posted the destination says "C:\Document ..." which is not a remote location.
james.king@4act.com
Post by james.king@4act.com » Wed Jun 25, 2008 9:16 pm
Hmm,
I had not noticed that before. I wonder to where it is attempting to copy? However, this happens when I drag the file out of my temporary queue into the folder above in the "Folders" view above. Which is a remote ftp location.
Why would it change the destination to a local folder on my machine?
Again, I can do the same thing if I use a file on a folder that is not mapped and it works just fine.
Post by mb » Wed Jun 25, 2008 9:23 pm
Bug confirmed. Working on a fix.
In the meanwhile you can directly drag&drop the files without using the temporary queue. Just drag and drop the files from the local browser to the remote browser.
