SmartFTP does not load up at all
meekamoo
Post by meekamoo » Wed Jun 25, 2008 9:17 am
hi there!
I've been running 2.5 for a long time now without any hassles but as soon as I upgraded to ver3 it refuses to load up at all.
I completely uninstalled 2.5 + rebooted before installing 3 (3.0.1018.1). I also tried the beta version of 3 (3.0.1018.3) - (As well as the 64bit vers but those complained I'm not running 64bit XP).
I am running a 64bit CPU but only 32bit XP. I've tried disabling DEP too.
AMD Athlon 64 X2 Dual Core 3800+
2gb ram
Windows XP SP2
after it installs I try open it and I get no response at all. No errors messages, no background task in task manager or anything. Mouse cursor says busy for a second or two then nothing.
I tried the crashdump too but that also seems to not be very useful. (I installed version 6.9.3.113 of the ms debugger)
C:\Program Files\SmartFTP Client>cscript "%ProgramFiles%\Debugging Tools for Windows (x86)\adplus.vbs" -crash -FullOnFirst -pn SmartFTP.exe -o C:\Dump
Microsoft (R) Windows Script Host Version 5.6
Copyright (C) Microsoft Corporation 1996-2001. All rights reserved.
C:\Program Files\Debugging Tools for Windows (x86)\adplus.vbs(2191, 4) Microsoft VBScript runtime error: Invalid procedure call or argument: 'Right'
http://rapidshare.com/files/124885043/Crash_Mode__Date_06-25-2008__Time_11-02-03AM.zip
Re: SmartFTP does not load up at all
Post by mb » Wed Jun 25, 2008 10:45 am
Try to delete the registry key at:
HKEY_CURRENT_USER\Software\SmartFTP
using regedit.exe
