Can't transfer AT ALL
danielpark
Post by danielpark » Tue Jun 24, 2008 7:41 pm
I can't seem to transfer files AT ALL since upgrading to the newest version. Not by drag-n-drop, not by transfer arrow buttons, not with the transfer queue. No way, no how.
Remote browser log:
[21:36:05] SmartFTP v3.0.1018.3
[21:36:06] Resolving host name "www.dappertext.com"
[21:36:06] Connecting to 65.98.83.20 Port: 21
[21:36:06] Connected to www.dappertext.com.
[21:36:06] 220---------- Welcome to Pure-FTPd [TLS] ----------
[21:36:06] 220-You are user number 2 of 50 allowed.
[21:36:06] 220-Local time is now 19:36. Server port: 21.
[21:36:06] 220-This is a private system - No anonymous login
[21:36:06] 220 You will be disconnected after 15 minutes of inactivity.
[21:36:06] USER danielpa
[21:36:06] 331 User danielpa OK. Password required
[21:36:06] PASS (hidden)
[21:36:07] 230-User danielpa has group access to: danielpa
[21:36:07] 230-This server supports FXP transfers
[21:36:07] 230 OK. Current restricted directory is /
[21:36:07] SYST
[21:36:07] 215 UNIX Type: L8
[21:36:07] Detected Server Type: UNIX
[21:36:07] FEAT
[21:36:07] 211-Extensions supported:
[21:36:07] EPRT
[21:36:07] IDLE
[21:36:07] MDTM
[21:36:07] SIZE
[21:36:07] REST STREAM
[21:36:07] MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
[21:36:07] MLSD
[21:36:07] ESTP
[21:36:07] PASV
[21:36:07] EPSV
[21:36:07] SPSV
[21:36:07] ESTA
[21:36:07] AUTH TLS
[21:36:07] PBSZ
[21:36:07] PROT
[21:36:07] 211 End.
[21:36:07] Detected Server Software: PureFTPd
[21:36:07] PWD
[21:36:07] 257 "/" is your current location
[21:36:07] CWD /public_html/camtasiastudio
[21:36:07] 250 OK. Current directory is /public_html/camtasiastudio
[21:36:07] PWD
[21:36:07] 257 "/public_html/camtasiastudio" is your current location
[21:36:07] TYPE A
[21:36:08] 200 TYPE is now ASCII
[21:36:08] PASV
[21:36:08] 227 Entering Passive Mode (65,98,83,20,187,191)
[21:36:08] Opening data connection to 65.98.83.20 Port: 48063
[21:36:08] MLSD
[21:36:08] 150 Accepted data connection
[21:36:08] 226-Options: -a -l
[21:36:08] 226 16 matches total
[21:36:08] 1922 bytes transferred. (11.5 KB/s) (163 ms)
[21:36:13] CWD /public_html
[21:36:13] 250 OK. Current directory is /public_html
[21:36:13] PWD
[21:36:14] 257 "/public_html" is your current location
[21:36:14] PASV
[21:36:14] 227 Entering Passive Mode (65,98,83,20,123,185)
[21:36:14] Opening data connection to 65.98.83.20 Port: 31673
[21:36:14] MLSD
[21:36:14] 150 Accepted data connection
[21:36:14] 226-Options: -a -l
[21:36:14] 226 86 matches total
[21:36:14] 10046 bytes transferred. (27.7 KB/s) (354 ms)
[21:36:19] CWD /public_html/floortime
[21:36:19] 250 OK. Current directory is /public_html/floortime
[21:36:19] PWD
[21:36:19] 257 "/public_html/floortime" is your current location
[21:36:19] PASV
[21:36:19] 227 Entering Passive Mode (65,98,83,20,177,204)
[21:36:19] Opening data connection to 65.98.83.20 Port: 45516
[21:36:19] MLSD
[21:36:19] 150 Accepted data connection
[21:36:19] 226-Options: -a -l
[21:36:19] 226 2 matches total
[21:36:19] 218 bytes transferred. (1.39 KB/s) (153 ms)
[21:36:50] NOOP
[21:36:50] 200 Zzz...
[21:37:21] NOOP
[21:37:21] 200 Zzz...
Multiple files don't work. Single files don't work. The file type appears to be irrelevant.
I've long enjoyed the free version of SmartFTP. The product has grown significantly in that time, and now that the "free lunch" is over, I'm happy to pay for the product, but only if it's actually functional.
cheers, Daniel
Re: Can't transfer AT ALL
Post by mb » Tue Jun 24, 2008 7:49 pm
Please post the system information from the menu: Help->About dialog.
mat
danielpark
Post by danielpark » Tue Jun 24, 2008 9:50 pm
Sure thing - here you go...
Service Pack 1 (Build 6001)
CPU Speed : 1870 MHz
Total Memory : 2047 MB
Free Memory : 1728 MB
Version : 3.0.1018.3
Time Stamp : 2008-06-24 17:31:48
Unlicensed
Days in use : 295
sfFTPLib.dll : 1.5.13.32
sfFavorites.dll : 1.0.14.3
sfTransferQueue.dll : 1.0.11.3
sfFTPShellExtension.dll : 1.0.9.3
SmartFTP.exe : 3.0.1018.3
Version : 7.0.6001.18000
Post by mb » Tue Jun 24, 2008 10:33 pm
It looks you have been affected by the same Windows Vista bug as here:
https://www.smartftp.com/forums/index.ph ... 0&start=20
The problem is actually with Windows Vista but it seems not even Microsoft has a 100% solution for it. Some users reported the subinacl fix (from Microsoft Support) described in above forum thread worked. For others Microsoft Support is still working on a solution after almost 1 month. It is important to note that not only SmartFTP is affected but any application that uses COM servers. It means on a system that shows such symptoms many other things will not work properly as well.
You can quickly verify that the problem is with Windows Vista:
1. Open the command line with administrative privileges (very important)
2. Select any COM server (this is typically a .dll file) and type regsvr32.exe yourdll.dll
For example you can go to the SmartFTP application folder cd %ProgramFiles%\SmartFTP Client and try to register the sfTransferQueue.dll by typing:
regsvr32.exe sfTransferQueue.dll
3. If 2 fails you know that there is a permission problem with Windows Vista.
Instead of doing step 2 you can also install SmartFTP from: https://www.smartftp.com/download
This setup will automatically elevate your user and register the COM servers. The setup will most likely fail due to the same permission problem.
danielpark
Post by danielpark » Wed Jun 25, 2008 8:40 am
FYI, your proposed solution DID work for me. Many thanks for your diligence.
cheers, d.
Post by mb » Wed Jun 25, 2008 10:46 am
Thank you for your feedback. Did you use the subinacl fix?
Post by mb » Tue Jul 08, 2008 2:51 am
The latest version of SmartFTP includes a workaround for the Windows Vista registry permission problem:
While this solves all the problems related with SmartFTP it does not fix the underlying registry permission problem. To fix this problem contact Microsoft Support or follow the instructions at the following post: https://www.smartftp.com/forums/index.ph ... st&p=47591
It is important to note that this problem has not been caused by SmartFTP and existed before you installed SmartFTP.
