Drag and drop Uploads to the root (wrong place)
bigorangemachine
Post by bigorangemachine » Tue Jun 24, 2008 5:49 pm
I have this weird drag and drop problem
I upload the files to a folder I have open (into the right pane of the remote viewer). I say overwrite or whatever
The files go into the queue but has no directory string. I.E. its suppose to go to the httpdocs/images/ folder but instead goes to the root (/ folder). When I do single files its fine. When I do multiple files it is not.
SMARTFTP
3.0.1018.1
WinXP Professional SP2
Re: Drag and drop Uploads to the root (wrong place)
Post by mb » Tue Jun 24, 2008 5:56 pm
It it doesn't work please be more specific on how to reproduce the problem.
bigorangemachine
Post by bigorangemachine » Tue Jun 24, 2008 6:37 pm
Hey thanks
Could you guys update this tread (https://www.smartftp.com/forums/Upload-P ... 14153.html) to say which version (3.0.1018.3) is the most current. I only downloaded this on Sunday (22nd) so I thought I had the latest version.
You can close this thread.
Post by mb » Tue Jun 24, 2008 6:41 pm
There is a changelog at:
https://www.smartftp.com/forums/SmartFTP ... 14037.html
Is your problem solved now?
bigorangemachine
Post by bigorangemachine » Tue Jun 24, 2008 8:11 pm
Yup
