Quirky view when viewing a Zip file using SmartFTP on Vista
Mathachew
Post by Mathachew » Fri Jun 06, 2008 10:35 pm
Please see the image below to view what I'm talking about. The column headers become little buttons, but they are not clickable. Also, selecting a file doesn't really select it according to the naked eye, though the file really is selected. I blurred the contents and highlighted the area in question. Thanks.
Re: Quirky view when viewing a Zip file using SmartFTP on Vista
Post by mb » Fri Jun 06, 2008 10:42 pm
Delete the registry key at: HKEY_CURRENT_USER\Software\SmartFTP using regedit.exe
Mathachew
Post by Mathachew » Fri Jun 06, 2008 11:19 pm
Well that definitely cleared it up, but now all my saved FTP accounts are gone. Would've been nice to have known that prior to deleting the key, but it fixed it. Thanks.
Post by mb » Fri Jun 06, 2008 11:21 pm
No the favorites are not gone. You can find them in the menu: Favorites->Quick Connect menu.
Mathachew
Post by Mathachew » Fri Jun 06, 2008 11:54 pm
Ah I see. Got a lot of old ones in there. Thanks
