UPLOAD PROBLEMS
fabian
UPLOAD PROBLEMS
Post by fabian » Fri Jun 06, 2008 1:33 pm
After installing the new version 3 i got this problem. EVERY file i try to copy/move onto the server gives the following prompt:
As you can see there is no any files/dirs with the name containing B.jpg at the server. It happens to EVERY file I try to copy.
Log:
[15:14:25] MLST B.jpg
[15:14:25] 250-Begin
[15:14:25]  type=dir;modify=20080606131437; /files/B.jpg
[15:14:25] 250 End.
[15:14:27] The operation has been added to the Transfer Queue. Check the Transfer Queue for the status.
[15:14:49] MLST B (2).jpg
[15:14:49] 250-Begin
[15:14:49]  type=file;size=355573;modify=20080403143339; /files/B (2).jpg
[15:14:49] 250 End.
Log from the Transfer Queue:
[15:14:28] Remote file exist check: "B (2).jpg".
[15:14:28] MLST B (2).jpg
[15:14:28] 250-Begin
[15:14:28]  type=dir;modify=20080606131437; /files/B (2).jpg
[15:14:28] 250 End.
[15:14:28] Source File: Size=355573, SizeUnit=Byte, Time=2008-04-03T14:33:39, TimeFormat=Exact
[15:14:28] Destination File: Size=0, SizeUnit=Byte, Time=2008-06-06T13:14:37, TimeFormat=Exact
[15:14:28] RecentTime=2008-06-06T13:14:28
[15:14:28] Rule "IF Destination Time=Recent AND Size=Smaller AND Transfer=No Matter THEN Resume" matched. Action="Resume".
[15:14:28] Compression disabled. File "B (2).jpg" matches exception "*.jpg".
[15:14:28] PASV
[15:14:28] 227 Entering Passive Mode (82,210,186,232,19,137)
[15:14:28] Opening data connection to 82.210.186.232 Port: 5001
[15:14:28] STOR B (2).jpg
[15:14:28] 150 Data connection accepted from 83.5.230.192:1643; transfer starting for /files/B (2).jpg
[15:14:47] 355573 bytes transferred. (17,7 KB/s) (00:00:19)
[15:14:49] 226 File received ok.
[15:14:49] MDTM 20080403143339 B (2).jpg
[15:14:49] 213 20080403143339
[15:14:49] 250 End.
[15:14:49] Timeout dynamically set to 60s
[15:14:49] XMD5 "B (2).jpg"
[15:14:49] 250 F0FE6865D7C3181AE3C350249EB91FB5
[15:14:49] Calculated MD5 hash of B.jpg: F0FE6865D7C3181AE3C350249EB91FB5
I also get similar prompt when trying to upload a directory, but there's a question about merging (when chosen - nothing changes), changing the name and using automatic rules (when chosen - the directory copies without problems).
System info:
 (Build 2600)
CPU Speed		   : 1664 MHz
Total Memory		: 767 MB
Free Memory		 : 278 MB
Version			 : 3.0.1016.15
Time Stamp		  : 2008-06-01 21:20:08
Platform			: x86
Unlicensed
Days in use		 : 1471
sfFTPLib.dll		: 1.5.13.29
sfFavorites.dll	 : 1.0.12.15
sfTransferQueue.dll : 1.0.9.15
sfFTPShellExtension.dll : 1.0.7.15
SmartFTP.exe		: 3.0.1016.15
Version			 : 6.0.2600.0000
Winsock			 : 2.2
Re: UPLOAD PROBLEMS
Post by mb » Fri Jun 06, 2008 4:59 pm
The bug is with the FTP server as you can see from the reply it sends:
The server says that B.jpg is a folder. (type=dir). Please contact the developers of the FTP server product.
fabian
Re: UPLOAD PROBLEMS
Post by fabian » Sun Jun 08, 2008 3:20 pm
is there a possibility to turn off that prompt and name changing into filename(2).jpg ?
in version 2 there wasn't anything like this.
Re: UPLOAD PROBLEMS
Post by mb » Sun Jun 08, 2008 7:53 pm
It's a bug with the server. To solve the problem the developers of the server product need to fix the problem.
