3.0.1016.7 problems on W2K
percepts
Post by percepts » Fri May 23, 2008 12:53 am
Was just forced to upgrade and these are some apprent bugs on W2K
1. right click context menu doesn't work in folders column (left)
2. My settings are set to download to default folder on double click. But file is added to transfer queue and then that has to be run to download.
I know I could have transfer queue switched on permanently but that is highly prone to problems if you accidentally put stuff in the queue.
Re: 3.0.1016.7 problems on W2K
Post by mb » Fri May 23, 2008 1:19 am
There are known problems on Windows 2000 since support for this operating system is limited.
I recommend you to install version 2.5 from:
percepts
Post by percepts » Fri May 23, 2008 2:05 am
Thanks, I have done that and all is working again.
