Cannot open, edit or view files - sfFTPShellExtension Unknown Error
rolij
Post by rolij » Sat May 10, 2008 8:31 am
Just updated to the latest version.
Since then I can't open edit or view files anymore.
All I get is a error window:
sfFTPShellExtension
Unbekannter Fehler
SmartFTP v3.0.1015.5
on Windows Vista SP1
Re: Cannot open, edit or view files - sfFTPShellExtension Unknown Error
Post by mb » Sat May 10, 2008 8:36 am
Do you use the German translation? If yes try the English translation.
If this doesn't help install the latest version from
know
Post by know » Mon May 12, 2008 1:36 am
Same problem here.
Using 64 bit version of smartftp (english)
(Vista ultimate 64 bit)
Post by mb » Mon May 12, 2008 1:05 pm
Then create a crash dump as described in this article:
https://www.smartftp.com/support/kb/how- ... f2594.html
Instead of using the -crash switch in the command line use -hang.
32-bit:
cscript "%ProgramFiles%\Debugging Tools for Windows\adplus.vbs" -hang -pn SmartFTP.exe -o C:\Dump
Run this command right after you see the error. If you need further instructions please let us know.
jcmurphy777
Post by jcmurphy777 » Wed May 14, 2008 1:59 am
having same problem.
i have Vista Ultimate
had 2.0 installed. then downloaded new version after it wouldnt open as i installed service pack 1 for vista.
tried removing 2.0 completely, removing the files from the appdata folder, restarted machine, installed new version and still same issue.
created all connections again to test. still same error.
here is my dump file.
http://rapidshare.com/files/114739189/P ... 4.rar.html
oh, the command for the debugger is also wrong for vista x86.
you put
it needs to be for default install
cscript "%ProgramFiles%\Debugging Tools for Windows (x86)\adplus.vbs" -hang -pn SmartFTP.exe -o C:\Dump
thanks
rolij
Post by rolij » Wed May 14, 2008 8:19 am
Just downloaded the latest version. I use original english version, no translations.
Still same problem.
Just recognized that I can't upload or download any file.
So in other words: SmartFTP is completely not working for me since I had to update to version 3.
Post by mb » Wed May 14, 2008 7:27 pm
jcmurphy, Roli: Are you interested to run a remote debug session? If yes please contact us at support attt smartftp.com
jcmurphy777
Post by jcmurphy777 » Wed May 14, 2008 11:54 pm
have the exact same thing roli.
sounds fine with me mb,
just will have have to tee up time when both awake.
Jason
acrisaf
Post by acrisaf » Thu May 15, 2008 11:01 am
I have Vista Ultimate SP1 installed
jcmurphy777
Post by jcmurphy777 » Thu May 15, 2008 5:31 pm
OK,
HERE IS THE FIX
DO EVERYTHING carefully.
it took me hours of mucking around to find the solutions but now all is working beautifully.
all this was found between two articles: plus loads of emails with Mat at support
http://blogs.msdn.com/astebner/archive/ ... 39820.aspx
http://forums.whirlpool.net.au/forum-re ... 05489.html
---------------FIRST-----------------------
Download the SubInACL tool
and install it. By default it will install to c:\Program Files\Windows Resource Kits\Tools
Grab the following file fromhere
Run the file AFTER installing the subinACL tool
or if you would rather manually create the file you can... see below
Go to the Start menu, choose Run, type cmd and click OK
Type notepad reset.cmd and click yes to create a new file named reset.cmd
Copy and paste the following contents into reset.cmd and then save and close it.
OR
cd /d "%programfiles%\Windows Resource Kits\Tools"
subinacl /subkeyreg HKEY_LOCAL_MACHINE /grant=administrators=f /grant=system=f
subinacl /subkeyreg HKEY_CURRENT_USER /grant=administrators=f /grant=system=f
subinacl /subkeyreg HKEY_CLASSES_ROOT /grant=administrators=f /grant=system=f
subinacl /subdirectories %SystemDrive% /grant=administrators=f /grant=system=f
subinacl /subdirectories %windir%\*.* /grant=administrators=f /grant=system=f
Run the reset.cmd file just created or downloaded.
This tool will take several minutes to run - be patient - took me 5 minutes i think it was.
Next restart the machine.
You will notice a whole lot of programs and windows services that dont want to start properly. network icons and network listings will be down etc.
Dont worry they will revert after the next step
---------- Step 2 ---------
next do the following (copied from the second link i gave at the start)
>>Right click "Computer"
>>Click "Manage"
>>Under the "System Tools" section, Double click "Local Users and Groups"
>>Click "Groups"
>>Right click "Administrators"
>>Click "Add to group..."
>>Click "Add"
>>Click "Advanced"
>>Click "Find Now"
>>Double click "Local Service"
>>Click "Ok"
>>Repeat to add "Network Service"
>>Click "OK"
>>"NT Authority\Local Service" and "NT Authority\Network Service" should show up in the list now
>>Click "OK"
>>Close Computer Management and reboot.
Done.
just for safe measure, re-install smartftp and restart again.
you will now have complete functionality of vista, plus some other issue to do with vista and service pack 1 will be gone... or atleast they were for me.
i had problem with windows update service pausing my computer every 10-15 seconds... seems to have fixed that as well.
Sweet... good to get that sorted.... now can ftp finally.
have fun.
