Sample working Script that uses FEAT and certificates
timcullis
Post by timcullis » Fri Nov 04, 2016 11:03 am
Hi, Does anyone have any sample scripts that allow connection to an FTP site that requires FEAT to be enabled, and access is controlled by a private certificate.
I can access the site using the GUI, but the sample scripts provided on the site don't show me how i can set the enumeration for the FEAT command,  So any help on how to set the FEAT command etc preferably in powershell or VB would be a great start.
Tim
Re: Sample working Script that uses FEAT and certificates
Post by mb » Fri Nov 04, 2016 8:17 pm
The powershell script is available here:
https://www.smartftp.com/ftplib/samples/sho ... Simple.ps1
