How to create an FTPS connection
ole
Post by ole » Mon Dec 03, 2012 12:08 pm
Hello
I have successfully connected to a remote host using the SmartFTP client. The connection is set up as FTPS (Explicit) with anonymous login with a client certificate enabled. All is working well.
However, I have to re-create this scenario using sfFTPLib and am having a hard time reading the c# samples and the documentation as to how to setup the connection. No samples seem to fit my requirements and the documentation leaves me even more confused.
Any starting help would be much appreciated.
Best regards
Ole
Re: How to create an FTPS connection
Post by mb » Mon Dec 03, 2012 12:24 pm
What language do you use? C#?
ole
Post by ole » Mon Dec 03, 2012 12:25 pm
C#, yes
vb.net could also do for examples
Post by mb » Mon Dec 03, 2012 3:38 pm
Please install the latest version of the ftp library:
It comes with an updated c# sample which shows how to select the protocol and client certificate.
ole
Post by ole » Tue Dec 04, 2012 7:54 am
Thank you. I will try to work with that.
Please note that the provided C# example doesn't compile, although not tested yet, it should read something like
System.Array certificateThumbprint = Array.CreateInstance(typeof (byte), 20);
certificateThumbprint.SetValue(0x12, 0);
certificateThumbprint.SetValue(0x34, 1);
// etc
_ftp.SSLSocketLayer.ClientCertThumbprint = Convert.ToBase64String((byte[]) certificateThumbprint);
Post by mb » Tue Dec 04, 2012 9:17 am
I think you still have the old version of the sfFTPLib.dll or the old interop. ClientCertThumbprint takes now a System.Array in c#, SAFEARRAY(BYTE) in c++.
