Delphi 2005 (Windows application)
stevenmason
Post by stevenmason » Fri May 06, 2011 3:06 pm
Hi
I have an existing program that I need to use the SmartFTP library in to connect to an FTPS server.
I'm having issues getting it to work however. I have installed the library, which has also given me the examples.
If I open the Delphi2005forWindowsDemo and run it, I get the following:
[Fatal Error] Delphi2005forWindowsDemo.dpr(10): F1026 File not found: 'sfFTPLib_TLB.dcu'
How do I get the project to use the library?
Thanks in advance!
Re: Delphi 2005 (Windows application)
Post by mb » Fri May 06, 2011 9:50 pm
You might need to add the COM library manually as a reference to the project?
