Scripts, license and trial
Olivier Bonnet
Post by Olivier Bonnet » Tue Apr 12, 2011 9:17 am
I am evaluating SmartFTP.
We are looking for a solution to make automatic our transfers with a FTPS server.
And I have two questions:
  • The difference of the scripting between SmartFTP Pro and the FTP Library. I have understood that the difference is that, with the FTP library, we are allowed to deploy the dll. Do you confirm?
  • For test purpose I have done a script in C#. I am still in the valid trial periode.
    using System;
    using System.Collections.Generic;
    using System.Linq;
    using System.Text;
    using sfFTPLib;
    namespace Notilus
        class Program
            static void Main(string[] args)
                /*sfFTPLib.Global global = new sfFTPLib.Global();
                if (global.LoadLicenseKeyData("..."))
                    System.Console.WriteLine("License key verified.");
                else
                    System.Console.WriteLine("Failed to verify license key.");*/
                // Create our COM object through the Interop
                FTPConnectionMTA ftp = new FTPConnectionMTA();
                // host settings
                ftp.Host = "*****";
                ftp.Port = 21;
                ftp.Username = "*****";
                ftp.Password = "*****";
                ftp.Passive = true;
                // connect to host
                sfFTPLib.enumError err = ftp.Connect();
                if (err == sfFTPLib.enumError.ftpErrorSuccess)
                    System.Console.WriteLine("Youpi!");
                    ftp.Disconnect();
                else
                    if (err == sfFTPLib.enumError.ftpErrorLicense)
                        System.Console.WriteLine("Please acquire a license from https://www.smartftp.com");
                    else
                        System.Console.WriteLine("Connect() failed. LastError = {0}", ftp.LastError);
    With this code, I receive always a license error (the famous error 17). Even if I uncomment the license part.
    Do you know what is wrong in my script?
Olivier
Saint-Gobain PPC
Re: Scripts, license and trial
Post by mb » Tue Apr 12, 2011 9:47 pm
>difference
Yes and you cannot directly access the FTP Library from the FTP client.
>trial
The trial has expired.
Post by mb » Sat Apr 16, 2011 1:22 am
>trial
You may want to try it again with the latest version:
https://www.smartftp.com/download/
It should give you another 30 day.
