IFTPConnection::DownloadFileEx keep file locked
alittera
Post by alittera » Thu Mar 03, 2011 1:55 pm
Hello,
I have the following problem. I use IFTPConnection::DownloadFileEx to download file, it is downloaded just fine. However even though method returned downloaded file is still locked for some time (i.e. CreateFile on it returns ERROR_SHARING_VIOLATION). Am i doing something wrong, or is it just bug in smartftplib? After some time file becomes unlocked again.
Re: IFTPConnection::DownloadFileEx keep file locked
Post by mb » Thu Mar 03, 2011 2:08 pm
Hello.
What is your license key id and what version of the FTP Library are you using?
alittera
Post by alittera » Thu Mar 03, 2011 3:49 pm
I'm using latest version 2.0.111.0. id:400081860
Post by mb » Thu Mar 03, 2011 4:08 pm
Thank you. Can you provide a sample (C#/C++/VB.NET) which reproduces the problem?
alittera
Post by alittera » Fri Mar 04, 2011 11:23 am
You can download sample C++ (Visual Studio 2010) project here.
Don't forget to enter your ftp login information and ftp remote file info in ftp_test.h
File locking doesn't happen 100% of the time. Sometimes its unlocked sometimes its not.
My test machine is Windows XP Pro SP3.
Post by mb » Fri Mar 04, 2011 6:43 pm
I have sent you the new version of sfFTPLib by email.
alittera
Post by alittera » Tue Mar 08, 2011 9:52 am
problem is fixed in 114, thanks
