Dim objFXP As New sfFTPLib.FTPFXP
Dim ftpSource as New sfFTPLib.FTPConnectionMTA
Dim ftpDest as New sfFTPLib.FTPConnectionMTA
Dim enumReturned As sfFTPLib.enumError
ftpSource.Host = "testServerOne"
ftpSource.Port = 21
ftpSource.Username = "test"
ftpSource.Password = "test"
ftpSource.Passive = true
ftpSource.DataProtection = enumDataProtection.ftpDataProtectionPrivate
ftpDest.Host = "testServerTwo"
ftpDest.Port = 21
ftpDest.Username = "test"
ftpDest.Password = "test"
ftpDest.Passive = false
ftpDest.DataProtection = enumDataProtection.ftpDataProtectionPrivate
objFXP.Source = _objFTPS
objFXP.Destination = objDestination
enumReturned = objFXP.FXPFile(fileName, fileName, 0, 0)
If enumReturned = sfFTPLib.enumError.ftpErrorSuccess Then
System.Console.writeLine("Success")
'ftpSource .Continue()
'ftpDest .Continue()
Else
System.Console.writeLine("Error Ocurred= " & objFXP.LastError.ToString)
End If
When I execute the above code, it does not always work - sometimes the file is transferred, other times it gives error as "ftpErrorPending" and does nothing, and yet other times it gives the error and the file is transferred completely.
Here is the log for source:
PASV Host: 202.189.230.246
227 Entering Passive Mode (202,189,230,246,45,110) Host: 202.189.230.246
Opening data connection to 202.189.230.246 Port: 11630 Host: 202.189.230.246
MLSD Host: 202.189.230.246
TransferStart -------------------- Customized message
OnTransferProgress: Low=0, High=0 -------------------- Customized message
150 Opening data connection Host: 202.189.230.246
1009 bytes transferred. (Unknown/s) (0 ms) Host: 202.189.230.246
OnTransferEnd -------------------- Customized message
226 Transfer complete Host: 202.189.230.246
OnTransferInit -------------------- Customized message
DownloadFXPFile: RemoteFile=TestFile.txt, Low=0, High=0 -------------------- Customized message
Error Ocurred= ftpErrorPending
Anyone have suggestions?
