AttributeBits, ValidAttributeBits, etc.
2BrightSparks
Post by 2BrightSparks » Mon Jan 03, 2011 1:07 pm
At the moment I'm upgrading from V1.5 to V2 and am confused about the attribute bits settings in the new V2. Using SFTP, could you give me an example of setting a files last modification date & time and also how to remove a read-only attribute from a file? Previously I used AttributeBits, ValidAttributes, and ValidAttributeBits, but now I see that ValidAttributes no longer exists, and neither do the definitions like ftpSFTPItemAttributeBitReadOnly etc.
Re: AttributeBits, ValidAttributeBits, etc.
Post by mb » Mon Jan 03, 2011 2:37 pm
>setting last modification time
Create new SFTPItem:
CComPtr<sfFTPLib::ISFTPItem> pItem;
pItem.CoCreateInstance(__uuidof(sfFTPLib::SFTPItem));
Set LastModifyTime
pItem->ModifyTimeAsFileTime = FILETIME;
pSFTPConnection->SetStat("path", pItem)
To check if an attribute exists use IsValidAttribute.
pItem->IsValidAttribute(sfFTPLib::ftpSFTPItemAttributeBits)
Please install the newest version.
>To remove attributebitreadonly
Create new SFTPItem
pNewItem->AttributeBits = pItem->AttributeBits & ~sfFTPLib::ftpSFTPItemAttributeBitReadOnly;
SetStat("path", pNewItem);
