Legacy replacement functions
RBygrave
Post by RBygrave » Sun Sep 26, 2010 3:42 pm
I have run into some other issues while upgradig some of our legacy code.
I used to do stream based operations rather than direct file IO.
Here is a snipit of the original code
public MemoryStream GetFile(string _fileName)
MemoryStream IN_Stream = new MemoryStream();
ftpIN.CloseStreamsAfterTransfer = false;
ftpIN.DownloadStream(IN_Stream, _fileName);
return IN_Stream
In the new libary I don't see the replacements for the stream operations. What would be the replacement functions for this?
Thanks in advance
Re: Legacy replacement functions
Post by mb » Sun Sep 26, 2010 5:25 pm
You may want to look at the following function:
HRESULT DownloadFileEx(
[in] BSTR bstrRemoteFile,
[in] VARIANT varLocalFile,
[in] long nRemoteStartPosLo,
[in] long nRemoteStartPosHi,
[in] long nLocalStartPosLo,
[in] long nLocalStartPosHi,
[out, retval] enumError * retval
varLocalFile
An indicator of the local file. This may be a path to a file (String/BSTR), an IStream or any object that supports IStream.
RBygrave
Post by RBygrave » Sun Sep 26, 2010 6:36 pm
I have re-written it like this, will see if it works on monday.
public MemoryStream GetFile(string fileName)
if (_Status != (int)Stat.OPEN)
_LastMessage = "Connection not open";
return null;
int nStartPosLo = 0,rStartPosLo = 0 ;
int nStartPosHi = 0, rStartPosHi = 0;
MemoryStream _strm = new MemoryStream();
_ftp.DataTransferMode = enumDataTransferMode.ftpDataTransferModeStream;
_ftp.DataProtection = enumDataProtection.ftpDataProtectionPrivate;
_ftp.DataTransferType = enumDataTransferType.ftpDataTransferTypeASCII;
err = _ftp.Download(fileName, (object)_strm, rStartPosLo, rStartPosHi, nStartPosLo, nStartPosHi);
if ( err == enumError.ftpErrorSuccess)
_strm.Seek(0, System.IO.SeekOrigin.Begin);
return _strm;
else
_LastMessage = MapError(err);
return null;
Post by mb » Thu Dec 09, 2010 3:35 am
That won't work because the C# Stream class does not implement the COM IStream interface. What you need is a IStream to C# Stream adapter. You can find one in the SmartFTP SDK:
https://www.smartftp.com/client/features/sdk
The adapter is located at Samples\TransferQueue\C#\Download\Interop\IStreamAdapater.cs
