File mask
RBygrave
File mask
Post by RBygrave » Fri Sep 24, 2010 6:35 pm
In the first version of the libary I had I do do a file mask on the file listing.
Now I have upgraded I no longer see the overloaded function GetFiles()
So now how do I apply a mask such as zbc*.t* to a directory listing?
Re: File mask
Post by mb » Fri Sep 24, 2010 6:36 pm
You need to filter the files yourself. What programming language do you use?
RBygrave
Re: File mask
Post by RBygrave » Fri Sep 24, 2010 7:33 pm
I use C#. What happened to the functionality that was in the libary before? I now have legacy code that will not upgrade without modifications.
Re: File mask
Post by mb » Sat Sep 25, 2010 6:37 am
Maybe you mean the ReadDirectoryFromCommand method.
If your server supports globbing you can use the function as following"
ReadDirectoryFromCommand("LIST zbc*.t*")
But the safer way is to manually enumerate the directory (see below).
Re: File mask
Post by mb » Sat Sep 25, 2010 6:49 am
For file globbing you can use the following function. Credits go to to Erwin at http://www.codeproject.com/KB/string/wildcmp.aspx
public static class StringExtensions
	public static bool WildcardMatch(this string str, string compare, bool ignoreCase)
		if (ignoreCase)
			return str.ToLower().WildcardMatch(compare.ToLower());
		else
			return str.WildcardMatch(compare);
	public static bool WildcardMatch(this string str, string compare)
		if (string.IsNullOrEmpty(compare))
			return str.Length == 0;
		int pS = 0;
		int pW = 0;
		int lS = str.Length;
		int lW = compare.Length;
		while (pS < lS && pW < lW && compare[pW] != '*')
			char wild = compare[pW];
			if (wild != '?' && wild != str[pS])
				return false;
			pW++;
			pS++;
		int pSm = 0;
		int pWm = 0;
		while (pS < lS && pW < lW)
			if (wild == '*')
				pW++;
				if (pW == lW)
					return true;
				pWm = pW;
				pSm = pS + 1;
			else if (wild == '?' || wild == str[pS])
				pW++;
				pS++;
			else
				pW = pWm;
				pS = pSm;
				pSm++;
		while (pW < lW && compare[pW] == '*')
			pW++;
		return pW == lW && pS == lS;
RBygrave
Re: File mask
Post by RBygrave » Sat Sep 25, 2010 9:31 pm
This will work for me, Thanks a lot.
In the first version there was a overloaded function called GetFiles(). You could pass in a wildcard as a parameter and it would only get the matches.
Richard
