Initialize fails on UPnPNATManager
dt_matthews
Post by dt_matthews » Tue Jun 08, 2010 12:19 pm
I am using the sample vb.net code and when I run it fails on the Initialize method call as below.
Dim objUPnP As sfFTPLib.UPnPNATManager
objUPnP = New sfFTPLib.UPnPNATManager
objUPnP.Initialize()
The stack trace is below. If someone could offer some wisdom as to why this is happening I'd greatly appreciate it.
regards,
dan
System.Runtime.InteropServices.COMException was unhandled
ErrorCode=-2147467259
Message=Error HRESULT E_FAIL has been returned from a call to a COM component.
Source=Interop.sfFTPLib
StackTrace:
at sfFTPLib.UPnPNATManagerClass.Initialize()
at BTS.PC.FTP.Init() in C:\Users\dmatthews\Local Projects\BTS.PC.Importer\BTS.PC.FTP\FTP.vb:line 184
at BTS.PC.FTP.SecureFTP(Object sourceFTPDirectory) in C:\Users\dmatthews\Local Projects\BTS.PC.Importer\BTS.PC.FTP\FTP.vb:line 51
at BTS.PC.Importer.FTPSender.SendFile(Object sender, FileSystemEventArgs e) in C:\Users\dmatthews\Local Projects\BTS.PC.Importer\FTPSender\FTPSender.vb:line 130
at System.IO.FileSystemWatcher.OnCreated(FileSystemEventArgs e)
at System.IO.FileSystemWatcher.NotifyFileSystemEventArgs(Int32 action, String name)
at System.IO.FileSystemWatcher.CompletionStatusChanged(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* overlappedPointer)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
InnerException:
Re: Initialize fails on UPnPNATManager
Post by mb » Tue Jun 08, 2010 12:20 pm
There is probably no UPnP capable device available. Catch the exception and ignore it.
dt_matthews
Post by dt_matthews » Tue Jun 08, 2010 1:01 pm
Thanks but when I ignore it I get an 'ftpErrorConnect' as LastError.
I have set the Host, Port, Username and Password and I can ping the target Host.
thanks,
dan
Post by mb » Tue Jun 08, 2010 1:10 pm
Set the LogFile.File property. Then take a look at the generated log file.
