ftpErrorNoOperation on _ftp.connect()
Lavi
Post by Lavi » Sun May 23, 2010 3:20 pm
well, Its very simple. I'm using the sample code without any modifications. when calling connect I recieve an enumError reply of ftpErrorNoOperation.
U guys have an Idea what I'm doing wrong here?
thanks alot,
Lavi
Re: ftpErrorNoOperation on _ftp.connect()
Post by mb » Sun May 23, 2010 5:22 pm
Take a look at the log file. Set the LogFile.File property.
Lavi
Post by Lavi » Mon May 24, 2010 6:56 am
so here's the thing:
When I use _ftp.LogFile.File = "DotNetInteropDemo.log";
I get: "InvalidCastException was unhandled"
"unable to cast COM object of type 'System.___ComObject' to interface type 'sfFTPLib.ILogFile'. This operation failed because the QueryInterface call on the COM component for the interface with IID'blabla' failed due to the following error: No such interface supported. ( exception from HRESULT blabla (E_NOINTERFACE ))"
Post by mb » Mon May 24, 2010 2:53 pm
You seem to be using an old version of the FTP Library. In the old version the property is just "LogFile":
_ftp.LogFile = "DotNetInteropDemo.log";
Alternatively install the latest version from here:
Then use the samples that come with this package.
Lavi
Post by Lavi » Tue May 25, 2010 8:13 am
I'm pretty sure its the latest version because I downloaded it a week ago.
but I'll reinstall it.
Could all these problems be because i'm trying to develop on a standalone computer with no internet? ( after I purchase the lib, I need it to work on an offline network dissconnected from the internet ).
Post by mb » Tue May 25, 2010 11:58 am
No your lack of Internet connectivity has nothing to do with it.
Lavi
Post by Lavi » Thu May 27, 2010 8:36 am
OK, I installed the latest version and it works. Thanks.
