smartftp library and win7 64bit
JimM
Post by JimM » Mon May 17, 2010 9:59 am
I have sftp library (1.5.17.24) and have just installed on new laptop running win7 64bit.
Should the library work with this os?
I'm getting an error when I try to create an instance of FTPConnectionMTA
(Retrieving the COM class factory for component with CLSID {B32243B2-7D9E-464D-A2A4-4117540E0F70} failed due to the following error: 800700c1.)
thanks,
J
Re: smartftp library and win7 64bit
Post by mb » Mon May 17, 2010 3:12 pm
You may want to try it with the latest version of the FTP Library.
JimM
Post by JimM » Mon May 17, 2010 4:15 pm
Downloaded latest version and still didn't work.
Post by mb » Mon May 17, 2010 4:26 pm
For technical support please renew the maintenance (technical support plan).
JimM
Post by JimM » Mon May 17, 2010 5:13 pm
hmmm - if I thought you had an answer I might ;-)
