Get Timeout after upgrade
RBygrave
Post by RBygrave » Wed Jan 13, 2010 6:25 pm
When we upgraded the library from 1.5 to 2, I hade to make the following change to old code to get it to compile
OLD //_ftp.ProxyType = sfFTPLib.enumProxyType.ftpProxyTypeNone;
OLD //_ftp.FTPProxyType = sfFTPLib.enumFTPProxyType.ftpFTPProxyTypeNone;
New _ftp.Proxy.Type = sfFTPLib.enumProxyType.ftpProxyTypeNone;
New _ftp.FTPProxy.Type = enumFTPProxyType.ftpFTPProxyTypeNone;
Also I am now getting a timeout when I try to connect. Are there other setting that I have to change for this version?
Richard
Re: Get Timeout after upgrade
Post by mb » Wed Jan 13, 2010 7:11 pm
Hello Richard ...
>timeout issue
Please try it with the latest version of the sfFTPLib:
RBygrave
Post by RBygrave » Wed Jan 13, 2010 7:16 pm
That is the version we are using. is there a setting I should be using, or is there a way to get my old dll to work?
RBygrave
Post by RBygrave » Wed Jan 13, 2010 7:18 pm
Here is the code where I set up the connection
FTPConnectionMTA _ftp = new FTPConnectionMTA();
//cTripleDES des = new cTripleDES();
_ftp.Host = Properties.Settings.Default.Address;
_ftp.Port = Properties.Settings.Default.Port;
_ftp.CertName = Properties.Settings.Default.Certificate;
_ftp.Username = Properties.Settings.Default.UserName;
//_ftp.Password = des.Decrypt(Properties.Settings.Default.Password.ToString());
_ftp.Password = Properties.Settings.Default.Password.ToString();
// des = null;
_ftp.Protocol = enumProtocol.ftpProtocolSSLExplicit;
_ftp.HidePassword = true;
_ftp.Passive = true;
_ftp.DataProtection = enumDataProtection.ftpDataProtectionPrivate;
// proxy settings;
_ftp.LogFile = @Properties.Settings.Default.FTPLOGName;// "c:\data\SFTPTransfer.log";
Post by mb » Wed Jan 13, 2010 7:49 pm
I have just uploaded this new version right before I made the post.
RBygrave
Post by RBygrave » Wed Jan 13, 2010 7:53 pm
I figured ot a fix for the time being. What I did was to download a new copy of the client application. This copied a new DLL that over rode the one in the libary (after all this is what broke the library in the first place and forced an unplanned upgrade) and now it works.
So I have the following questions. Are you planning to fix the client install so it does not break the library? After all why should a client pay for an upgarade just to fix a flaw in the client install. When will a fix for the current library come out?
Thank You
Post by mb » Wed Jan 13, 2010 7:59 pm
>1st question
The client should not break your application (maybe the opposite is the case) because it uses a SxS manifest. I recommend you do the same for your application. See the Side By Side Execution article in the help file (chm).
>2nd question
See above (first reply)
