License issue
verisource
License issue
Post by verisource » Wed Sep 16, 2009 8:14 pm
I purchased smartftp client and installed it and it works. I previously (in 2007) purchased the library and wrote several applications that have been running since then. After the client install, the VB6 IDE gives an automation error if I read the license file, and LoadLicenseKeyData failure message if I hard code it in the program
Re: License issue
Post by mb » Thu Sep 17, 2009 3:18 am
Make sure that the correct sfFTPLib.dll (the one you have a license for) is registered (regsvr32.exe sfFTPLib.dll).
verisource
Re: License issue
Post by verisource » Thu Sep 17, 2009 1:27 pm
Thanks. That was it.
RBygrave
Re: License issue
Post by RBygrave » Tue Jan 12, 2010 7:16 pm
Same thing here, after installing the client my app that uses the libary is broken. I just tried re-registering the dll, but still doesn't work. What can I do to fix this.
