Deployment problem (vs2008)
JimM
Post by JimM » Fri Jun 05, 2009 5:44 pm
Trying to deploy an application, I have come across a problem. (deployed prog will not start up)
I have read the section on side by side execution, and have pasted in the code into my application manifest.
Trying to build it gives 'Error 5 Could not find file 'sfFTPLib, Version=1.5.0.0, Culture=*, ProcessorArchitecture=x86, Type=win32'. ClipStore'
I have sfFTPLib.dll (ver 1.5.17.24) and Interop.sfFTPLib.dll (ver 1.5.0.0) in my application directory.
pasted in from the helpfile is
<dependency>
<dependentAssembly>
<assemblyIdentity
type="win32"
name="sfFTPLib"
version="1.5.0.0"
language="*"
processorArchitecture="x86"
</dependentAssembly>
</dependency>
Any ideas?
thnx
Jim
Re: Deployment problem (vs2008)
Post by mb » Fri Jun 05, 2009 6:00 pm
Hello Jim ..
Is this the error message from Visual Studio? Did you add the sfFTPLib.dll as a reference in your project? Maybe you have to readd it.
If you register the dll you don't need a manifest. If you want to use SxS you need to add the part from the help file to your manifest.
JimM
Post by JimM » Sat Jun 06, 2009 12:43 pm
Hello Jim ..
Got the manifest working in the end. My mistake.
Jim
