Problem with SFTP
m.gunesch
Problem with SFTP
Post by m.gunesch » Tue Mar 31, 2009 6:57 am
We have encountered again problems with SFTP:
When I try to connect to a server, the ftp library crashes at "If objFTP.Connect = sfFTPLib.enumError.ftpErrorSuccess Then"
You can try it with your VB6 sample project and following server:
objFTP.Host = "ftpd.ils-consult.fr"
objFTP.Port = 22
objFTP.Username = "smartftp"
objFTP.Password = "smartftp"
objFTP.LogFile = "c:\sftp.log"
I really need some help, because at the moment it's not possible to use SFTP with SmartFTP-Library.
Markus
Re: Problem with SFTP
Post by mb » Tue Mar 31, 2009 10:43 am
I will take a look at it. In the meanwhile try to set the objFTP.UseMessageLoop property to true
m.gunesch
Post by m.gunesch » Tue Mar 31, 2009 11:25 am
No change if I set objFTP.UseMessageLoop property to true ...
Post by mb » Tue Mar 31, 2009 11:33 am
Are the VBScript examples (Scripts\Simple.wsf) working for you?
m.gunesch
Post by m.gunesch » Tue Mar 31, 2009 1:31 pm
No. Almost the same error msg except it's WScript.exe instead of VB6.exe
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:\WINDOWS\System32\WScript.exe
This application has requestet the Runtime to terminate it in an unusual way. Please contact the application's support team for more information
Post by mb » Tue Mar 31, 2009 8:56 pm
What operating system are you using?
Can you to reproduce the problem on a fresh installation of Windows?
m.gunesch
Post by m.gunesch » Wed Apr 01, 2009 7:24 am
Windows XP Professional SP3.
I have tried it with a new XP installation, same error with the script examples.
Post by mb » Wed Apr 01, 2009 1:18 pm
I couldn't not find any errors with the script nor the ftp library. They both work as expected. Do you have the latest version of the FTP Library: https://www.smartftp.com/ftplib
Did you register the sfFTPLib.dll (regsvr32.exe sfFTPLib.dll)?
m.gunesch
Post by m.gunesch » Thu Apr 02, 2009 7:46 am
Yes, I have!
[20090402 07:22:39] SmartFTP FTP Library v1.5.17.28
[20090402 07:22:39] Resolving host name "ftpd.ils-consult.fr"
[20090402 07:22:39] Connecting to 92.103.148.120 Port: 22
[20090402 07:22:39] SSH-2.0-OpenSSH_4.7
[20090402 07:22:39] Starting SSH session. Remote Id: "SSH-2.0-OpenSSH_4.7"
[20090402 07:22:39] SSH protocol version reply. Client Id: "SSH-2.0-SmartFTP"
[20090402 07:22:41] Computing session key.
[20090402 07:22:41] Key Exchange Algorithm: diffie-hellman-group-exchange-sha256
[20090402 07:22:41] Key exchange completed.
[20090402 07:22:41] Host Key Algorithm: ssh-rsa
[20090402 07:22:41] Client to Server Encryption: aes128-ctr
[20090402 07:22:41] Server to Client Encryption: aes128-ctr
[20090402 07:22:41] Session MAC: hmac-sha1
[20090402 07:22:41] Client to Server Compression: zlib@openssh.com
[20090402 07:22:41] Server to Client Compression: zlib@openssh.com
[20090402 07:22:41] Authentication request. Method: "none"
[20090402 07:22:41] Server supported authentications: publickey,password,keyboard-interactive
[20090402 07:22:41] Authentication request. Method: "password"
[20090402 07:22:42] User authentication successful.
That's the last message which can be found in the log file.
Did you try the VB6-Sample with the parameters I have posted?
objFTP.Port = 22
I have tried it on different PCs, always the same problem with "If objFTP.Connect = sfFTPLib.enumError.ftpErrorSuccess Then"
The problem doesn't occur if I use a nonexistent username, then I'll get an error ftpErrorConnect = 25L
objFTP.Port = 22
objFTP.Username = "abcdefg"
objFTP.Password = "......."
Markus
m.gunesch
Post by m.gunesch » Thu Apr 02, 2009 1:18 pm
I have installed the latest SmartFTP-Client on 5 PCs and it's impossible to connect to ftpd.ils-consult.fr!
Always error message and crash.
