FXP transfer and progress monitoring
JimM
Post by JimM » Tue Mar 24, 2009 9:26 am
This follows on from a post I read in the pre-sales forum..
I would like to monitor progress of fxp transfers by the suggested route of monitoring the destination file size periodically (this being the only way to do it?).
When I start the FXPFile method, then it blocks till completed, so I have put that into a background worker thread (I'm using c# vs2008).
If I want to monitor progress, would I then start a new connection to the destination ftp server in my main thread and send a destination file size request via the GetFileSize method?
How would I then get the result as it's going to take some time? Do I have to check the .LastFileSize periodically, or is there an event I can look for?
Apologies if these are basic questions!
Jim
Re: FXP transfer and progress monitoring
Post by mb » Tue Mar 24, 2009 10:05 am
Yes that's exactly what you would need to do: Open an extra connection to the destination and use the GetFileSize method periodically. The result of the GetFileSize method is saved in the LastFileSize property.
JimM
Post by JimM » Tue Mar 24, 2009 10:52 am
So, does GetFileSize block until it gets a filesize result from the server? - (presumably with a timeout if it doesn't get an answer?)
Is there an asynchronous way of getting the file size?
Jim
Post by mb » Tue Mar 24, 2009 11:16 am
All the functions are blocking. But GetFileSize() is fast and you get the result immediately.
