License problem with Windows 2000
m.gunesch
Post by m.gunesch » Tue Mar 03, 2009 2:12 pm
Dear all,
We encountered problems on some machines running Windows 2000.
The methods LoadLicenseKeyFile or LoadLicenseKeyData fail although there is correct license information.
I have set the LogLevel to highest value, as you can see there is a problem creating the MSXML::DOMDocument
LoadLicenseKeyData
20090303 14:56:16.802 Thread(580) Log file opened. LogLevel=7
20090303 14:56:16.802 Thread(580) Set LogLevel to 4294967295.
20090303 14:56:16.812 Thread(580) CLicenseKey::LoadData()
20090303 14:56:16.812 Thread(580) CLicenseKey::LoadDataText()
20090303 14:56:16.812 Thread(580) CLicenseKey::LoadDataXML()
20090303 14:56:16.822 Thread(580) CLicenseKey::LoadDataXML() CreateInstance(__uuidof(MSXML::DOMDocument)) failed (0x80040154).
20090303 14:58:09.203 Thread(580) Log file closed.
LoadLicenseKeyFile
20090303 14:58:12.678 Thread(936) Log file opened. LogLevel=7
20090303 14:58:12.678 Thread(936) Set LogLevel to 4294967295.
20090303 14:58:12.678 Thread(936) CLicenseKey::LoadFile(C:\Documents and Settings\ils\Bureau\key.xml)
20090303 14:58:12.678 Thread(936) CLicenseKey::LoadXML()
20090303 14:58:12.688 Thread(936) CLicenseKey::LoadXML() Failed to create MSXML::DOMDocument hr=-2147467259
20090303 14:58:23.524 Thread(936) Log file closed.
The problem is, that this happens not on all machines running Windwos 2000. We have some PCs with 2k and it works.
Maybe you have a great idea how to solve this problem :-)
Thanks in advance!
BR Markus
Re: License problem with Windows 2000
Post by mb » Tue Mar 03, 2009 2:36 pm
It seems the MSXML component is not correctly installed on the machines where you see the problem. The 0X80040154 error is: CLASS NOT REGISTERED
Try to install the newest MSXML updates.
m.gunesch
Post by m.gunesch » Tue Mar 03, 2009 3:09 pm
I have already tried to install MSXML 4.0, MSXML 5.0 and MSXML 6.0 and it didn't work.
Last try was to install "Microsoft XML Parser (MSXML) 3.0 Service Pack 7 (SP7)" and taaataaaaa it's ok now.
Microsoft ... Oo
Thanks for your help!
BR,
Markus
Post by mb » Tue Mar 03, 2009 3:36 pm
Yes the FTP Library uses MSXML 3.0 because we thought it's available on every system. Apparently not always.
