FTP with SSL, Clear Command Channel
kevingauvin
Post by kevingauvin » Wed Feb 04, 2009 4:56 pm
HI,
I've got a site that I want to FTP to using the FTP Library. The Admin on the remote server say that I need to do a "Clear command channel" in order to get through his firewall. I don't have a clue as to what he's talking about. Is this even possible to do with smartftp?
kevin
Re: FTP with SSL, Clear Command Channel
Post by mb » Wed Feb 04, 2009 10:43 pm
Yes of course.
FTPLib:
Set the CommandProtection property (of the FTPConnection) to ftpDataProtectionClear = 1
SmartFTP:
Just go to the Favorite properties. Then go to the Connection->SSL dialog and set the control connection to Clear.
kevingauvin
Post by kevingauvin » Thu Feb 05, 2009 2:58 pm
I guess I still don't fully understand how to write the "ftpDataProtectionClear = 1". Do you have some sample code that I could look at. Here's what I've got so far but I know "objFTP.ftpDataProtectionClear = 1" is not right.
Dim objFTP
Set objFTP = CreateObject("sfFTPLib.FTPConnectionSTA")
objFTP.Host = "xxx.xxx.xxx.xxx"
objFTP.Username = "abcd1243"
objFTP.Password = "zxcv9876"
objFTP.Port = 21
path= "/to_xpn"
objFTP.Connect()
Post by mb » Thu Feb 05, 2009 4:12 pm
You forgot to set the Protocol property to SSLExplicit.
kevingauvin
Post by kevingauvin » Thu Feb 05, 2009 5:18 pm
Thanks for all of the help Mat.
I added what you suggested and I am getting an error saying "Object doesn't support this property or method: 'ftpDataProtectionClear' ", It's failing on this line of the script "objFTP.ftpDataProtectionClear = 1" .
Any ideas?
Post by mb » Thu Feb 05, 2009 6:11 pm
CommandProtection is the name of the property. ftpDataProtectionClear is the name of the constant. So the correct line is:
objFTP.CommandProtection = 1
kevingauvin
Post by kevingauvin » Fri Feb 06, 2009 1:01 pm
Same kind of error. I should mention that I'm using the FTPLib and writing the code as VB script.
I am getting an error saying "Object doesn't support this property or method: 'CommandProtection' , It's failing on this line of the script "objFTP.CommandProtection = 1" .
Thanks for taking the time to help me with this problem
Post by mb » Fri Feb 06, 2009 9:30 pm
Works here as expected. Make sure that you have the latest version of the FTP Library installed:
https://www.smartftp.com/get/SFTPFTPLib.exe
kevingauvin
Post by kevingauvin » Mon Feb 09, 2009 6:19 pm
Yes, the most current version does work on my pc. I was able to get my script to run. now I'll just have to sort out why I'm getting a return code of 17 after I execute the connect.
I currently have a license for FTPLib and I am running version 1.5.9.16 on our production server. Do you know if the new version of the dll will allow me to use the same license or do I require an upgrade.
Kevin
Post by mb » Mon Feb 09, 2009 6:27 pm
Dear Kevin ..
Please contact us at sales@smartftp.com and provide your license key id.
