sftp for vbscript
kevingauvin
sftp for vbscript
Post by kevingauvin » Thu Jan 29, 2009 6:50 pm
I am currently using the FTP Library to ftp files using a vbscript. I am basically using the example from the smartftp website on how to upload a file from VBscript. I was just wondering if it's possible to use a vbscript to upload files with sftp.
Kevin
Re: sftp for vbscript
Post by mb » Thu Jan 29, 2009 9:19 pm
Dear Kevin ..
You can find an example in the FTPLib installation package. Just go to the Samples\SFTP\Script folder.
kevingauvin
Post by kevingauvin » Tue Feb 03, 2009 2:17 pm
thanks Mat,
I found the script. when I execute I get an error saying "ActiveX component can't create object sfFTPLib.SFTPconnection"
it's failing on
Set objFTP = CreateObject("sfFTPLib.SFTPConnection")
Any ideas?
Dear Kevin ..
Post by mb » Tue Feb 03, 2009 3:17 pm
Register the sfFTPLib.dll
regsvr32.exe sfFTPLib.dll
kevingauvin
Post by kevingauvin » Tue Feb 03, 2009 5:23 pm
Thanks Mat,
I was able to successfully register the dll. Unfortunately I got the same error message about not being able to create the object.
I really thought that was the fix for the problem. Maybe I have an older dll or something.
Any ideas?
Post by mb » Tue Feb 03, 2009 9:21 pm
Are the Samples\FTP\Scripts working?
kevingauvin
Post by kevingauvin » Wed Feb 04, 2009 1:13 pm
Yes, the Samples\FTP\Scripts are working for me. I am able to connect to a remote server and upload files. I am able to create the following object " Set obj = CreateObject("sfFTPLib.FTPConnectionSTA") "
Post by mb » Wed Feb 04, 2009 4:40 pm
I'm not sure why the SFTP examples are not working for you. Did you try it on a different system?
kevingauvin
Post by kevingauvin » Wed Feb 04, 2009 4:57 pm
I'll try it on a different machine and see if I still get the same problem.
