DownloadFile Arithmetic operation resulted in an overflow
NemisisJedi
Post by NemisisJedi » Fri Nov 28, 2008 12:16 pm
I am using the DownloadFile function via a FTPConnectionMTA and i am getting the following error on this bit of code
ERROR = Arithmetic operation resulted in an overflow.
CODE
mFtp.DownloadFile("REMOTEFILENAME", "LOCALFILENAME", 2148751482, 0)
I am resuming a download of a file that has a remoteSize of 7243113984
Does anyone know why this is happening? I believe that the download is failing as the input is an integer data type which is a max value of 2147483647, and my value is above it. Is this a bug? Should it be a long data type instead of an integer??
Thanks for your help in advanced.
Re: DownloadFile Arithmetic operation resulted in an overflow
Post by mb » Fri Nov 28, 2008 1:32 pm
What programming language are you using?
NemisisJedi
Post by NemisisJedi » Fri Nov 28, 2008 1:40 pm
Vb.NET
Post by mb » Fri Nov 28, 2008 1:42 pm
Can you post a bit more of the code? Or do you use the numeric 2148751482 in the arguments?
NemisisJedi
Post by NemisisJedi » Fri Nov 28, 2008 1:49 pm
The value 2148751482 is being passed into the DownloadFile procedure. My code looks like
mFtp.DownloadFile(pRemoteFile, pLocalFileInfo.FullName, pLocalFileSize, 0)
pRemoteFile = Remote File Name
pLocalFileInfo = FileInfo where localfile is to be saved
pLocalFileSize = Long value, containing the length of the file held locally, so a resume download can be done
Post by mb » Fri Nov 28, 2008 1:53 pm
You have to split the position into 2 32-bit longs. In C# this looks something like that:
DownloadFile(source, dest, (int)pLocalFileSize, (int)(pLocalFileSize >> 32))
NemisisJedi
Post by NemisisJedi » Fri Nov 28, 2008 1:56 pm
Ok, so i do not need to pass a 0 in as the last parameter, even if i am/am not doing a resume?
Post by mb » Fri Nov 28, 2008 2:09 pm
It depends on what position you resume.
NemisisJedi
Post by NemisisJedi » Fri Nov 28, 2008 2:20 pm
I would like to resume at the end of the local file, if the local file exists, else it starts from the beginning
Post by mb » Fri Nov 28, 2008 2:23 pm
If the local file doesn't exist you use 0,0 for the arguments otherwise you use the method I described in my last post:
