Unbuffered Write
JimS
Unbuffered Write
Post by JimS » Tue Nov 11, 2008 2:51 pm
First off, great tool!
Is there a way to have SmartFTP write the file in unbuffered mode? When downloading very large files if it is not done in unbuffered mode I run into problems. Can this be set or is SmartFTP always using buffered?
Re: Unbuffered Write
Post by mb » Tue Nov 11, 2008 4:30 pm
How exactly would this work? Flush the buffer after every write? You can disable the write back cache in Windows and of your harddisk and achive the same effect.
