Unable to load private key
cwmathew
Post by cwmathew » Mon Sep 22, 2008 2:44 pm
We recently purchased two licenses for the pro version which supports scripting. Was the PrivateKey property left out of the “Application” layer?
The following works fine, has it uses the library which I don’t need as I only have two servers…
[codebox]
Dim loEarlyConnection As sfFTPLib.SFTPConnection = New sfFTPLib.SFTPConnection
Dim loEarlyKeyManager As sfFTPLib.KeyManager = New sfFTPLib.KeyManager
loEarlyConnection.Host = "123.45.679.11"
loEarlyConnection.Username = "UserName"
loEarlyConnection.Port = 22
loEarlyConnection.LogFile = "c:\TestFTPLog.log"
loEarlyConnection.PrivateKey = loEarlyKeyManager.LoadFile("c:\Keys\PrivateKey.ppk", "")[/codebox]
Using the Application does not...
[codebox]
Dim loFTPApplication As Object = CreateObject("SmartFTP.Application")
Dim loConnection As Object = loFTPApplication.CreateObject("sfFTPLib.SFTPConnection")
Dim loKeyManager As Object = loFTPApplication.CreateObject("sfFTPLib.KeyManager")
loConnection.Host = "123.45.679.11"
loConnection.Username = "UserName"
loConnection.Port = 22
loConnection.LogFile = "c:\TestFTPLog.log"
loConnection.PrivateKey = loKeyManager.LoadFile("c:\Keys\PrivateKey.ppk", "")[/codebox]
Re: Unable to load private key
Post by mb » Mon Sep 22, 2008 3:26 pm
What error do you get? Do you get an exception when assinging the PrivateKey?
Can you connect to the server? If yes can you post the log from the TestFTPLog.log.
cwmathew
Post by cwmathew » Mon Sep 22, 2008 3:40 pm
The error I am receiving is…
VB.NET - {"Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))"}
In VB Script I receive Object doesn’t support this property or method.
And no I am unable to connect as this server requires authentication by use of a key. Thus the log file is empty.
Post by mb » Mon Sep 22, 2008 3:59 pm
The LoadFile method or the PrivateKey method?
cwmathew
Post by cwmathew » Mon Sep 22, 2008 4:04 pm
The PrivateKey method.
Post by mb » Mon Sep 22, 2008 4:10 pm
Install the latest version of SmartFTP:
Then register the sfFTPLib.dll:
regsvr32.exe sfFTPLib.dll
I think the proxy was not registered.
cwmathew
Post by cwmathew » Mon Sep 22, 2008 5:14 pm
Post by mb » Mon Sep 22, 2008 8:13 pm
I created the following .wsf script and it didn't throw any errors:
<?xml version="1.0"?>
<package>
<job>
<reference object="SmartFTP.Application" />
<reference object="sfFTPLib.SFTPConnection" />
<script language="VBScript">
<![CDATA[
Option Explicit
Dim objSmartFTP
'Set objSmartFTP = WScript.CreateObject("SmartFTP.Application")
Set objSmartFTP = GetObject(,"SmartFTP.Application")
Dim objFTP
Set objFTP = objSmartFTP.CreateObject("sfFTPLib.SFTPConnection")
Dim objKeyManager
Set objKeyManager = objSmartFTP.CreateObject("sfFTPLib.KeyManager")
Dim objKey
Set objKey = objKeyManager.LoadFile("C:\PrivateKey", "")
objFTP.PrivateKey = objKey
WScript.Echo("Done")
</script>
</job>
</package>
cwmathew
Post by cwmathew » Mon Sep 22, 2008 8:57 pm
Post by mb » Mon Sep 22, 2008 9:06 pm
Both ways should be working.
