smartFTP compatibility with Compact Framework v2.0
kcee
Post by kcee » Fri Aug 01, 2008 8:40 pm
Hello there~
It seems most of the people here are having successes in using smartFTP for their applications. But not me. HELP me out guys
I am trying to use smartFTP library for Visual Basic .net in Visual Studio 2005. The compiled application in .exe will run on Windows CE 5.0 based device running arm4i processor. However, I am not seeing any successes in number of different tries I have attempted on the device using the smartFTP library.
The following is the code that I used. (most of the code, pretty much all, has been written using the post in this forum):
Imports sfFTPLib
Public Class smartFTPTest1
	Public Shared Sub main()
		Dim myFTPServices As New FTPServices
		If (myFTPServices.EstablishConnection()) Then
			Console.WriteLine("Successful!!")
		End If
		MsgBox("I am here!!!", MsgBoxStyle.ApplicationModal)
	End Sub
	Public Class FTPServices
		Dim strUsername As String = "username"
		Dim strPassword As String = "********"
		Dim strServer As String
		'Public objFTP As New sfFTPLib.SFTPConnection
		Dim objFTP As sfFTPLib.FTPConnectionMTAClass = New sfFTPLib.FTPConnectionMTA
		'objFTP = New sfFTPlib.FTPConnectionMTA
		Public Function EstablishConnection() As Boolean
			' Function - FTPServices.EstablishConnection
			' Written by - Syd O
			' Created on - 27 May '08
			' Last Update -
			' Function Purpose - To establish connection to FTP Server Securely
			If vbTrue Then ' Currently a Stub for testing & evaluation. ALWAY WILL RETURN TRUE
				' note Server is Gene6 FTP and is configured to accept Explicit SSL on port 21
				' The server operates with SmartFTP client and has no issues we are aware of
				strServer = "www.anSFTPwebsite.com" ' Only For Testing
				objFTP.Host = strServer
				objFTP.Port = 22
				objFTP.Protocol = sfFTPLib.enumProtocol.ftpProtocolSSLExplicit
				objFTP.Username = strUsername
				objFTP.Password = strPassword
				objFTP.MLST = True
				objFTP.Passive = True
				'objFTP.ClientHostname = System.Environment.MachineName
				'objFTP.Proxy.Type = enumProxyType.ftpProxyTypeNone
				'objFTP.Client = "VBExpress"
				'objFTP.LogFile = System.Environment.MachineName + ".log"
				Select Case objFTP.Connect()
					Case enumError.ftpErrorSuccess
						MsgBox("Connected")
					Case Else
						MsgBox(enumError.ftpErrorConnect.ToString)
				End Select
			End If
		End Function
	End Class
End Class
Here is the error message upon deploying the application:
COMException was unhandled:
COM object with CLSID '{B32243B2-7D9E-464D-A2A4-4117540E0F70}' cannot be created due to the following error: 0x80040154
To the best of my knowledge, I think the COM component must be used when a piece of code is designed in a different platform and the developer needs to use that module. How would I go about fixing this? Am I understanding the problem correctly?
I will be spending sleepless nights until this gets solved. Please save me from those sleepless nights, guys.
Thanks for all your future help in advance.
- Kevin
Re: smartFTP compatibility with Compact Framework v2.0
Post by mb » Fri Aug 01, 2008 9:08 pm
I don't think the SmartFTP FTP Library component runs on Windows CE 5.0.
kcee
Post by kcee » Sun Aug 03, 2008 6:59 am
So you don't think that I can somehow add component hacks to resolve the interfacing?
Thanks in advance.
Post by mb » Sun Aug 03, 2008 7:08 am
No sorry. Windows CE only supports a very limited subset of the Windows API.
mat
