KeyManager.LoadFile - DISP_E_MEMBERNOTFOUND
broomm
Post by broomm » Fri Jul 25, 2008 12:32 pm
I'm trying to get our private key setup for an sftp connection and this works fine using the library sdk but when trying to use the SmartFTP Application object / pro scripting I get a [DISP_E_MEMBERNOTFOUND] exception generated in the line highlighted below.
objFTP = CreateObject("sfFTPLib.SFTPConnection")
objFTP.Host = My.Settings.SFTPAddress
objFTP.Port = 22
objFTP.Username = My.Settings.SFTPUsername
' load our private key
Dim keymanager As Object = CreateObject("sfFTPLib.KeyManager")
objFTP.PrivateKey = keymanager.LoadFile("C:\sftp-keys\smh-vrs.ppk", "mypassword")
Am I doing something wrong? Your help would be appreciated.
Many Thanks
Mark
Re: KeyManager.LoadFile - DISP_E_MEMBERNOTFOUND
Post by mb » Fri Jul 25, 2008 3:26 pm
What if you declare the keymanger as:
Dim keymanager As sfFTPLib.KeyManager
Please consider purchasing a licenes for the FTP Library if you require support for scripting since the Pro Edition does not offer support for scripting.
