Licencing in VB.NET (2005)
We've just purchased a licence online and we then try and impliment it in our code but we get an odd message.... Our code is basically...
Public WithEvents objFTPConnection As New sfFTPLib.FTPConnectionSTA
Dim strKey As String = ""
strKey = strKey & "-----BEGIN KEY-----" & vbCrLf
strKey = strKey & "Product: SmartFTP FTP Library" & vbCrLf
strKey = strKey & "ID: 400060367" & vbCrLf
strKey = strKey & "User: Administrator" & vbCrLf
strKey = strKey & "Company: NAME SUPPLIED" & vbCrLf
strKey = strKey & "Email: User@ourdomain.com" & vbCrLf
strKey = strKey & "Version: 2.0" & vbCrLf
strKey = strKey & "Number of Users: 1" & vbCrLf
strKey = strKey & "Date of Issue: 2008-07-23" & vbCrLf
strKey = strKey & "Maintenance Expiration: 2009-07-23" & vbCrLf
strKey = strKey & "-----BEGIN SIGNATURE-----" & vbCrLf
strKey = strKey & "KEY REMOVED" & vbCrLf
strKey = strKey & "-----END SIGNATURE-----" & vbCrLf
Try
If objFTPConnection.LoadLicenceKeyData(strKey) Then
MsgBox("Success")
Else
MsgBox("Fail")
End If
But we get an error 'Public Member LoadLicenceKeyData on Type FTPConnectionSTAClass not found'
Put me out of my misery and tell me what I've done wrong?
Syd
Try
MsgBox("Success")
Else
MsgBox("Fail")
End If
Syd
- Contact:
Re: Licencing in VB.NET (2005)
It's LoadLicenseKeyData and not LoadLicenceKeyData
So s instead of a c
So s instead of a c
So s instead of a c
Mat,
We did that and still get the same error message!
- Contact:
Please post your code here. You can assume that the LoadLicenseKeyData function exists. So the problem is very likely somewhere in your code.
I also think you are using the wrong license key format. The new format is based on XML. Please take a look at the C# example.
dim objFTPConenction = new sfFTPLib.FTPConnectionSTA
strKey = "<License><Version>2.0</Version><Id>400060367</Id><Name>Administrator</Name><Email>anthony.coker@nsureexpress.com</Email><Company>oolio online limited</Company><Product>SmartFTP FTP Library</Product><Features><Feature>FTP</Feature></Features><Users>1</Users><Maintenance>2009-07-23</Maintenance><Issue>2008-07-23</Issue><Signature>ilR07MgVhn5GHMIgKmthox5rsclEfIc69ohtWRphYxnC0hQsrf1UyZFSkerFmRB1EoJZrrdvZkT/6UDgXiWIWIsSzYJZH4siWJZpZIE4UpkHXw1ULYve09tyDnw8EMZvXoNWkJLGzyWhKEHompatA5hDQqKD
Gk+FQZoP9w3bOBuIqZ7oq/bCnoDFRiKkPbON6pd5//z/xOdeAOkxmTPuama7ZqYlq5FLNYt3xH49wkgmYBjUQukQ==</Signature></License>"
Try
If Not objftpConnection.LoadLicenseKeyData(strKey) Then
GenericServices.MessageBoxCriticalOKOnly(My.Resources.LicenceKeyFailure)
Application.Exit()
End If
objFTPConnection.Host = objSettings.Server.ToString
objFTPConnection.Port = 21
objFTPConnection.Username = objSettings.Username.ToString
objFTPConnection.Password = objSettings.Password.ToString & A1012
objFTPConnection.Protocol = enumProtocol.ftpProtocolSSLExplicit
objFTPConnection.Proxy.Type = enumProxyType.ftpProxyTypeNone
objFTPConnection.Client = System.Environment.MachineName
objFTPConnection.LogFile = ""
objFTPConnection.DataTransferMode = enumDataTransferMode.ftpDataTransferModeZ
objFTPConnection.Async = False
objFTPConnection.LISTOption = enumLISTOption.ftpLISTOptionLong
objFTPConnection.TransferProgressEventInterval = 1000
objFTPConnection.DataProtection = enumDataProtection.ftpDataProtectionPrivate
objFTPConnection.Timeout = 60
AddHandler objFTPConnection.OnTransferProgress, AddressOf OnTransferProgress
Select Case objFTPConnection.Connect()
- Contact:
The FTPConnection interface has no LoadLicenseKeyData method. You have to use the Global interface for that.
Also your strKey is still wrong. You forgot to add the following part:
strKey = strKey & "<?xml version=\""1.0\"" ?>" & Chr(13) & Chr(10)
Why don't use the VB.NET sample which is included in our product?
- Contact:
Dim objGlobal As sfFTPLib.[Global]
'objGlobal = CreateObject("sfFTPLib.Global")
objGlobal = New sfFTPLib.[Global]
' strKey = strKey & "-----BEGIN KEY-----" & Chr(13) & Chr(10)
' strKey = strKey & "Product: SmartFTP FTP Library" & Chr(13) & Chr(10)
' strKey = strKey & "ID: 400000000" & Chr(13) & Chr(10)
' strKey = strKey & "User: user" & Chr(13) & Chr(10)
' strKey = strKey & "Company: my company" & Chr(13) & Chr(10)
' strKey = strKey & "Email: user@host.com" & Chr(13) & Chr(10)
' strKey = strKey & "Version: 1.0" & Chr(13) & Chr(10)
' strKey = strKey & "Number of Users: 1" & Chr(13) & Chr(10)
' strKey = strKey & "Date of Issue: 2005-04-05" & Chr(13) & Chr(10)
' strKey = strKey & "Maintenance Expiration: 2006-04-05" & Chr(13) & Chr(10)
' strKey = strKey & "-----BEGIN SIGNATURE-----" & Chr(13) & Chr(10)
' strKey = strKey & "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" & Chr(13) & Chr(10)
' strKey = strKey & "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx==" & Chr(13) & Chr(10)
' strKey = strKey & "-----END SIGNATURE-----" & Chr(13) & Chr(10)
' New license key format
strKey = ""
strKey = strKey & "<License>" & Chr(13) & Chr(10)
strKey = strKey & "<Version>2.0</Version>" & Chr(13) & Chr(10)
strKey = strKey & "<Id>400012345</Id>" & Chr(13) & Chr(10)
strKey = strKey & "<Name>name</Name>" & Chr(13) & Chr(10)
strKey = strKey & "<Email>user@host.com</Email>" & Chr(13) & Chr(10)
strKey = strKey & "<Company>company</Company>" & Chr(13) & Chr(10)
strKey = strKey & "<Product>SmartFTP FTP Library</Product>" & Chr(13) & Chr(10)
strKey = strKey & "<Features>" & Chr(13) & Chr(10)
strKey = strKey & "<Feature>SFTP</Feature>" & Chr(13) & Chr(10)
strKey = strKey & "</Features>" & Chr(13) & Chr(10)
strKey = strKey & "<Users>1</Users>" & Chr(13) & Chr(10)
strKey = strKey & "<Maintenance>2008-12-27</Maintenance>" & Chr(13) & Chr(10)
strKey = strKey & "<Issue>2007-12-27</Issue>" & Chr(13) & Chr(10)
strKey = strKey & "<Signature>xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx</Signature>" & Chr(13) & Chr(10)
strKey = strKey & "</License>" & Chr(13) & Chr(10)
' Load License Key
If objGlobal.LoadLicenseKeyData(strKey) Then
System.Console.WriteLine("License key verified.")
Else
System.Console.WriteLine("Failed to verify license key.")
End If
