Can not Connect SSH Using Library v1.5.13.28
HSI
Post by HSI » Tue Jun 03, 2008 3:03 pm
We cannot connect to any SSH sites of our 4 clients. We are using vb6 or vb.net (.Port = 22).
Any FTP site with or without SSL is ok. Can you help or provide us sample code? Thanks
Re: Can not Connect SSH Using Library v1.5.13.28
Post by mb » Tue Jun 03, 2008 8:16 pm
Please post the VB.NET code you have and we can take a look at it. The C# sample should be very similiar to the VB.NET. You can find it in the Samples\SFTP\CSharp folder.
HSI
Post by HSI » Tue Jun 03, 2008 9:43 pm
OK. Connected. Thanks
Post by mb » Wed Jun 04, 2008 5:37 am
I have added a VB.NET sample to the setup package. It is included in the latest version https://www.smartftp.com/ftplib/download
