Adding resume capability to a C# application
zephyr26
Post by zephyr26 » Sat Apr 26, 2008 7:32 am
How should the parameters nStartPosLo and nStartPosHi in the DownloadFile function, be set while using the sfFTPLib.dll component in a C# application? Assuming we can retrive the position at which file transfer was stopped so do we provide that byte value or is there some other method?
Re: Adding resume capability to a C# application
Post by mb » Sat Apr 26, 2008 12:23 pm
Use the GetFileSize() function to get the size of the remote file. Then pass the values to the nStartPosLo and nStartPosHi arguments of the DownloadFile function.
