Running different versions on same server?
Toobster
Post by Toobster » Fri Nov 23, 2007 1:06 pm
Hello,
We are encountering problems with different versions of the Smartftp component. Websites that are running different versions cannt coexist on same server? The problem is that when one site wants to use a newer version all other (10s of applications) has to be rebuilt using the newer version.
How are we suppose to handle that?
Re: Running different versions on same server?
Post by mb » Fri Nov 23, 2007 7:52 pm
Use SxS (Side by Side Execution) using a manifest and the component doesn't need to be registered. There is an article in the help file (.chm).
Nikeware
Post by Nikeware » Thu May 08, 2008 2:17 pm
Post by mb » Thu May 08, 2008 6:09 pm
We are using the sfFTPLib with SxS in SmartFTP and the events are fired.
