426 Connection Closed
mgruodis
Post by mgruodis » Fri Mar 28, 2003 7:14 pm
My 30 day evaluation expired today. I registered that program and now am receiving the following messege:
An established connection was aborted by the software in your host machine.
426 Connection Closed; transfer aborted.
Any thoughts?
Re: 426 Connection Closed
Post by mb » Fri Mar 28, 2003 7:50 pm
I've searched the knowledge base and found this article:
https://www.smartftp.com/support/kb/ind ... view&id=66
You can enable/disable passive/active mode in the settings dialog at:
Menu: Tools->Settings->Connection "Data Connection Mode"
But there can be other causes for your problem. Please send the full log that we can get a better idea of what is not working.
Do you get this message just after the RETR, STOR or LIST command is sent or after the transfer has started?
