Problem Accessing FTP Server
rikhabex
Post by rikhabex » Fri Mar 14, 2003 1:29 pm
We have problems using SmartFTP to access a FTP Server. With other tools it works very well.
The complete problem description is available on:
http://www.habex.org/smartftp.doc
We just purchased SmartFTP licenses and our Customer Support Engineers (that have to use this tool very frequently) are really struggling with this issue.
Please help us!
Kind regards,
Rik Habex
rik.habex@damovo.com
Carlos
Re: Problem Accessing FTP Server
Post by Carlos » Fri Mar 14, 2003 2:25 pm
try to update the the latest build. and try again and see if solve the problem.
nice explanition of the problem.
you think you can attech some raw listing if posible?
thanks in advance.
carlos
rikhabex
Post by rikhabex » Fri Mar 14, 2003 2:34 pm
I upgraded to the latest build (1.0.973) and it's still the same problem. I think the LIST export that my FTP server sends is a little bit different then the LIST export that other FTP servers are sending (the folders are moved some characters to the right). SmartFTP then picks up the foldernames as "________xxxxx", so with a few spaces in front of the foldername. The FTP server is maybe a little bit old-fashioned, but other FTP tools do not have any problems at all with this...
Thanks for your quick reply already! :wink:
Cheers,
/Rik
This is a raw list:
220 FUSION FTP server ready.
USER MDUSER
331 User name okay, need password.
PASS (hidden)
230 User logged in, proceed.
SYST
215 MD110 BC10 system type.
REST 100
502 Command not implemented.
TYPE I
200 Command okay.
REST 100
PWD
257 "/" is current directory.
TYPE A
200 Command okay.
PORT 10,12,21,235,7,247
200 Command okay.
Opening data connection IP: 10.12.21.235 PORT: 2039.
LIST
150 LIST
612 bytes received successfully. (612 B/s) (00:00:01).
226 Closing data connection.
CWD / USR1
521 "/ USR1" is not a directory
NOOP
200 Command okay.
Post by mb » Fri Mar 14, 2003 7:21 pm
Hello Rik
Excellent bug report :-)
The first step is to upgrade to the latest developer build:
- Install https://www.smartftp.com/download
We need the raw directory listing of a few directories to fix the problem.
- Connect to FTP server
- Right-click on a folder in the tree view
Select "Show Raw Directory" listing from the context menu
- Do the same for some other folders
Send all raw directory listings to bugreport aaatttt smartftp dot com
The problem will be fixed within 1-2 working days as soon as we have the listings.
rikhabex
Post by rikhabex » Sat Mar 15, 2003 10:38 am
Hi All,
I installed SFTPDev.exe succesfully.
I created 3 rawlistings (had to use manual commands for that as I could not change directories, but it's OK)
I sent everything in a ZIP file to bugreport (at) smartftp (dot) com.
The rawlistings are also available via:
http://www.habex.org/rawlist1.txt
http://www.habex.org/rawlist2.txt
http://www.habex.org/rawlist3.txt
We currently stopped the deployment of SmartFTP towards our client PC's. As soon as you have an updated version ready let us know and we will test it immediately...
Thanks for this great support!
Cheers,
/Rik
Post by mb » Sat Mar 15, 2003 9:14 pm
New build sent to Rick in personal email.
rikhabex
Post by rikhabex » Mon Mar 17, 2003 7:35 am
I downloaded the new build this morning, and the problem is still the same? I checked the version and it's :
Service Pack 3 (Build 2195)
CPU Speed : 1132 MHz
Total Memory : 261040 KB
Free Memory : 89440 KB
Version : 1.0.974.16
Time Stamp : 2003-03-16 17:55:30
Controls.dll : 1.6.974.16
FTPAPI.dll : 2.0.974.16
Language.dll : 1.0.974.16
ResEng.dll : 1.3.974.16
shell32.dll : 5.00.3502.5436
shlwapi.dll : 6.00.2800.1106
comctl32.dll : 5.81
riched20.dll : 5.30.23.1209
schannel.dll : 5.00.2195.5284
Version : 6.0.2800.1106
Is something not correctly upgraded?
Cheers and thanks!
/Rik
Post by mb » Tue Mar 18, 2003 2:38 am
The user reported the problem has been fixed with the latest "private" build.
