Registration key problem
seanderson
Post by seanderson » Sun Dec 08, 2002 10:24 pm
Just registered the other day, and need to install on new system that just got put together. Reg key does not work. System is on a small net and machine name is not the same if that matters.
User: Stephen Anderson
Company: SEA Consulting
Email: register@foamingSEA.com
Version: 1.0
Number: 1
Tell me what to do.
Re: Registration key problem
Post by mb » Mon Dec 09, 2002 3:29 am
If the key worked on the old sytem it also works on the new one. Make sure you have the latest build (1.0.971) installed and correctly copied the key file from the email to the SmartFTP directory.
seanderson
Post by seanderson » Wed Dec 11, 2002 4:24 am
Tried that more than once. Doesn't work using cut and paste, but just tried using import file and BINGO!
Thank you. Love the program.
Louie
Post by Louie » Wed Dec 11, 2002 4:36 am
Good to hear :wink:
