No menu or shortcut after reinstalling
rletter
Post by rletter » Sat Sep 17, 2011 10:33 pm
My desktop disappeard and in "all programs" the only thing I get are tools and registration number. To get the program I have to reinstall and run but it still does not put anything in menus.
Re: No menu or shortcut after reinstalling
Post by mb » Sun Sep 18, 2011 12:01 am
Uninstall SmartFTP from the Control Panel->Programs.
Reboot your computer
Install SmartFTP from here: https://www.smartftp.com/download/
rletter
Post by rletter » Sun Sep 18, 2011 6:35 pm
I tried uninstalingl SmartFTP program (left data file) rebooted and reinstalled from the SmartFTP site before I made my first post. Still no menu item nor shortcut. It picked up some old data this time. I want to keep the most recent backup data as well as fix the lost menu and shortcut. Any help would be appreciated.
Post by mb » Sun Sep 18, 2011 9:33 pm
You can manually create a shortcut to the SmartFTP.exe in the %ProgramFiles%\SmartFTP Client folder.
rletter
Post by rletter » Mon Sep 19, 2011 3:50 am
I was able to "pin" a shortcut to the taskbar but not to the desktop. Since the SmatrFTP site was down last night late, I downloaded the most recrent 64 bit version today. It did not pick up the lastest backup settings. Only one favorite and I had to reajust the views etc. How do I make sure the most recent data is picked up? Can I use the "repair" and somehow point it to the most recent data and pick it up that way? I hate to have to to retype all of the favoites data. Still something weird about this installation. Thanks much!
Post by mb » Mon Sep 19, 2011 10:57 am
Please add your license key id to the forum for premium support.
rletter
Post by rletter » Mon Sep 19, 2011 2:28 pm
SmartFTP Client License Key
License Key Summary
Post by mb » Mon Sep 19, 2011 6:41 pm
The favorites are stored in the %appdata%\SmartFTP\Client 2.0\Favorites folder. They are never deleted during uninstall/reinstall.Maybe they are still there? In SmartFTP, take a look at the menu: Favorites->Quick Connect.
rletter
Post by rletter » Mon Sep 19, 2011 9:43 pm
Thanks, I found them.
This still doesn't answer why I cannot find SmartFTP in the "all programs menu" and it doesn’t install it during "remove and reinstall' but I can now access the program since I "pinned" it to the task bar.
Post by mb » Mon Sep 19, 2011 10:32 pm
I do not have any answers for that. But it is most likely a problem with your system/os.
