Error On ssh SFTP
invader980
Error On ssh SFTP
Post by invader980 » Fri Jul 08, 2011 5:16 pm
Is there an archive of old versions we can download ? Heres my situation:
I just purchased a license but previously was using a trail that just ran out ( NOT AN ISSUE AT ALL , worked flawless).
After purchase i realize im running an older version of smartftp so i download the latest.
Same settings (carries over from the last install): i get an error trying to connect to the same site ive been using for a month previous.
10:02:20] SmartFTP v4.0.1204.0
[10:02:20] Resolving host name "****.seedunlimited.com"
[10:02:21] Connecting to **** Port: 20722
[10:02:21] SSH-2.0-OpenSSH_5.5
[10:02:21] Starting SSH session. Remote Id: "SSH-2.0-OpenSSH_5.5"
[10:02:21] SSH protocol version reply. Client Id: SSH-2.0-SmartFTP
[10:02:21] Key Exchange Algorithm: diffie-hellman-group-exchange-sha256
[10:02:22] Key exchange completed.
[10:02:22] Host Key Algorithm: ssh-rsa
[10:02:22] Client to Server Encryption: aes128-ctr
[10:02:22] Server to Client Encryption: aes128-ctr
[10:02:22] Session MAC: hmac-sha1
[10:02:22] Client to Server Compression: zlib@openssh.com
[10:02:22] Server to Client Compression: zlib@openssh.com
[10:02:22] Requesting service "ssh-userauth".
[10:02:23] RTT: 379.836 ms
[10:02:23] Authentication request. Method: none
[10:02:23] Server supported authentications: publickey,password,keyboard-interactive
[10:02:23] Authentication request. Method: password
[10:02:23] User authentication successful.
[10:02:23] SSH session established.
[10:02:23] Connected to ***.seedunlimited.com.
[10:02:23] Detected Server Software: OpenSSH
[10:02:23] Opening channel 0.
[10:03:23] Timeout (60s).
[10:03:23] SSH channel closed by client.
[10:03:23] Connect failed. Error=0x8004440b
[10:03:23] Disconnecting.
So i assume it just may be an error caused by some old settings that need to be updated , I go regedit and delete my old setting ( start fresh)
This version of smartftp returns the same error without a timeout (60)s
After playing with the ssh settings to find something that would work i eventually start getting the following error:
[10:12:15] SmartFTP v4.0.1204.0
[10:12:15] Resolving host name "***.seedunlimited.com"
[10:12:15] Connecting to *** Port: 20722
[10:12:15] SSH-2.0-OpenSSH_5.5
[10:12:15] Starting SSH session. Remote Id: "SSH-2.0-OpenSSH_5.5"
[10:12:15] SSH protocol version reply. Client Id: SSH-2.0-SmartFTP
[10:12:15] Server closed connection
[10:12:15] Connect failed. Error=0x80004005
[10:12:15] Waiting to retry (30s)...
which i assume is my ftp server spitting me out because of the connection errors
<<Scratching my head>> Im at a loss the only thing i can think is theres a prob with the build,but nowhere on the site id there a place to download old builds to rule this out. Any ideas?
i love the software i dont understand y it no longer loves me lol
ps: **** = my username is included on the host name
Re: Error On ssh SFTP
Post by mb » Fri Jul 08, 2011 5:18 pm
Please email the account information for the server to premium support. This will allow us to reproduce the problem here and if there is a bug provide a fix. Thank you.
invader980
Post by invader980 » Fri Jul 08, 2011 5:33 pm
Done ... thanx for the quick reply
Post by mb » Fri Jul 08, 2011 6:01 pm
SFTP is not configured on the server:
19:58:12] Channel request failed (Local=0, Remote=0).
[19:58:12] Failed to open sftp subsystem. Attempting fallback.
[19:58:12] Requesting exec command="test -x /usr/lib/sftp-server && exec /usr/lib/sftp-server
[19:58:12] test -x /usr/local/lib/sftp-server && exec /usr/local/lib/sftp-server
[19:58:12] exec sftp-server" (Local=0, Remote=0).
[19:58:12] Channel request failed (Local=0, Remote=0).
It doesnt work with other clients either.
invader980
Post by invader980 » Fri Jul 08, 2011 7:04 pm
Confirmed... tested it on a local sftp server and connected fine .... guess i shouldn't have ruled out the server lol
will keep u posted thanx for clarifying.
invader980
Post by invader980 » Fri Jul 08, 2011 9:14 pm
Edit****: Nvm problem solved ... server was having Sporadic problems including ftp issues ...
Thanks again for the speedy support , sadly u responded correctly and much faster then the server admins i pay monthly if only the rest of the world worked perfectly lol
