Can't see contents
SShelp
Can't see contents
Post by SShelp » Sat Jul 02, 2011 12:24 am
I am not seeing any contents being displayed with the new version of SmartFTP 4.0.1203.0. Connection to the FTP server is successful.
When I close the SmartFTP app and I will see the contents for a split of second.
Older version of SmartFTP works find, but not working after upgrade.
Please help
Re: Can't see contents
Post by mb » Sat Jul 02, 2011 12:26 am
Please post the system information from the menu: Help->About "System Information" dialog.
SShelp
Post by SShelp » Sat Jul 02, 2011 12:43 am
here you go:
Microsoft Windows 7 Enterprise Edition
(Build 7600)
CPU Speed : 2992 MHz
Total Memory : 2047 MB
Free Memory : 2047 MB
Version : 4.0.1203.0
Time Stamp : 2011-06-30 16:17:45
Maintenance : 2012-01-19
Days in use : 234
en-US
Version : 8.0.7600.16385
Post by mb » Sat Jul 02, 2011 12:47 am
SShelp
Post by SShelp » Sat Jul 02, 2011 12:57 am
No, it didn't work. Still seeing no contents, but connection is fine. I can get the content display using Internet Explorer 8. This happens on my 64bit Windows 7 system as well.
Post by mb » Sat Jul 02, 2011 1:54 pm
Please post a screenshot.
Shadowl0rd
Post by Shadowl0rd » Sun Jul 31, 2011 10:35 am
Same problem here... in the screenshot you will see only an emty folder.. when the files are there...
I cant use the program at all... please URGENT
Shadowl0rd
Post by Shadowl0rd » Sun Jul 31, 2011 10:39 am
here is the screenshot
Post by mb » Sun Jul 31, 2011 2:38 pm
Right-click on the folder (D) then select "Show Raw Listing" from the context menu. This will show you what the server returns.
Shadowl0rd
Post by Shadowl0rd » Sun Jul 31, 2011 3:05 pm
It show nothing... an empty txt
If I use any other FTP program It works perfect
When I used the old Smartftp It works Perfect (But now If I try to downgrade to an old smartftp it doesn't fix the problem
System Info:
Microsoft Windows 7 Ultimate Edition
Service Pack 1 (Build 7601)
CPU Speed : 3340 MHz
Total Memory : 12279 MB
Free Memory : 8380 MB
Version : 4.0.1207.0
Time Stamp : 2011-07-18 00:44:56
Platform : x64
Maintenance : 2012-11-30
Days in use : 453
es-ES
Version : 9.0.8112.16421
