few questions - usability
GordonHo
Post by GordonHo » Sat Jun 18, 2011 12:44 pm
hi, i've few questions regarding the usability of smartftp
- is it possible to turn off animations ? (eg. when adding a file to the queue)
- are there keyboard shortcuts to select all changed / new files and transmit those to / from server ?
- alt tabbing to smartftp has some kind of lag, is it somehow possible to avoid this?
- terminal window: the window sometimes times out, is it possible to have some sort of keep alive and the option to simply reconnect?
cheers
Re: few questions - usability
Post by mb » Sat Jun 18, 2011 6:15 pm
https://www.smartftp.com/support/kb/how- ... f2603.html
No. You can simply drag&drop the complete folder or all files and SmartFTP will automatically detect which files to transfer.
We don't see any lags here. Do you run Windows 7 with enough free memory?
Go to the Favorite Properties and under the SSH dialog enable the keep alive. This should prevent the terminal from getting disconnected.
